Performance advice?
Old Aug 8, 2010 | 12:10 PM
twangysmitty's Avatar
twangysmitty
Performance advice?
I have a 95 f150 302 and I'm trying to give it more hp. It has a catback exhaust and I'm not sure what the next step should be. I want the most bang for my buck without killing my mpg. Any advice?
Old Aug 8, 2010 | 12:46 PM
lew52's Avatar
lew52
Long tube headers & free flowing exhaust is a good place to start , a good tune up , autolite coppers , MSD cap wires & coil , advance the timing a few degress......Lew
Old Aug 8, 2010 | 12:56 PM
twangysmitty
I was thinking about long tube headers but then i'd have to replace the y pipe to fit right? I live in pa so I need cats and a muffler unfortunately
Old Aug 8, 2010 | 12:57 PM
96ford250's Avatar
96ford250
a new cam will do wonders for these motors
Old Aug 8, 2010 | 01:14 PM
twangysmitty
Where could i find a good cam? Ive tried looking and have only found ones for the 351
Old Aug 8, 2010 | 01:27 PM
lew52's Avatar
lew52
The 302 & 351 use the same cam ...
Old Aug 8, 2010 | 02:00 PM
Encho's Avatar
Encho
The Southernmost Mod
You should look the Windsor engines part of the forum, there is a wealth of info regarding performance there. Btw, did you try the six litre tune up already? it's a cheap/fast way to gain some more power.
You probably have a MAF setup there, so cam choices will be even better, i would ask Conanski about a good setup, i guess it all depends on money and time.
Old Aug 8, 2010 | 02:44 PM
Fair 96's Avatar
Fair 96
This is a good mod that can help and it is easy to put on. The intake tube goes right on the original box relocating where the cold air goes into it. Just a thought.
https://www.ford-trucks.com/forums/9...r-upgrade.html
Old Aug 8, 2010 | 03:03 PM
lew52's Avatar
lew52
sounds like your just looking for some more HP , nothing major , what kind of truck is it , 2wd or 4wd , if you don't want to go LT, shortys will work ok you just need a better y pipe , the Ho cam may be a good choice , if you want to change cams , gearing is very important on the 302 , it makes better hp in the higher rpms , underdrive pulleys & e fan will help take a load off the engine & help power & fuel mileage....
Old Aug 8, 2010 | 07:19 PM
ymeski56's Avatar
ymeski56
Der Postmeister
FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs
Old Aug 10, 2010 | 03:26 PM
twangysmitty
Alright im thinking about going in the cam direction first.. any warnings before i get them? or anything that i should get to compliment the cam?
Old Aug 10, 2010 | 03:34 PM
lew52's Avatar
lew52
Depending on the valve lift ? , valve springs . Roller rockers are nice to go with your roller cam , you can even go from 1.6 to 1.7 ratio to give the cam more lift....Lew
Old Aug 10, 2010 | 03:52 PM
danger-ranger93's Avatar
danger-ranger93
some 1.7 roller rockers would compliment the cam
Old Aug 10, 2010 | 04:28 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Might find this interesting:
Cam Advance and Hi Flow Water Pump Completed - Ford F150 Forum - Community of Ford Truck Fans
Old Aug 10, 2010 | 04:31 PM
lew52's Avatar
lew52
The stock rocker ratio is 1.6 so if you use 1.7 or 1.72 it will give the cam more lift , i use the 1.72 rockers on an E 303 cam & made a good difference....
