I have a 2009 F350 6.4 diesel with 19k miles on it and had 2 injectors stick open (5&8), no engine lights came on just started running rough. It is at the dealer now, pulled the head found #5 rocker arm and valve are bent.
To get this fixed the dealer has to pull the cab to get to #5?
Has anyone had something similar happen, if so what problems can I expect down the road if any!
Your truck was designed to have the cab removed to work on the motor. **** poor design in my opinion (once the warranty goes out), but since it was made specifically for that, don't worry about removing the cab.
Usually stuck open injectors tend to put holes in pistons. If you just need a valve job and some new rockers, the only issues I see is you'll be without your truck for a couple of weeks.
Welcome to FTE. Be sure to scroll further down the main forum listing and read up in the 6.4 diesel section.
