Cruise Control swap
Old Aug 7, 2010 | 06:52 PM
hacking_in2002's Avatar
hacking_in2002
Cruise Control swap
I'm in the process of swapping over cruise components from an '85 F-150 w/ manual 4.9 to a '81 F-150 w/ auto 4.9. From most of my parts catalog, it looks as though everything thing is the same (part #'s and such) Does anyone know what parts are swappable? Any pics of this setup from either year would also be of help!
Old Apr 26, 2011 | 08:30 PM
hacking_in2002
Hopefully someone will chime in....I pulled the harness and computer for the cruise today. Though I've hit a snag. Seeing as how I plan on swapping the column from the 85 everything should plug right in, except the plug for the switch on the clutch pedal. My 81 is an auto, so does anyone know if this can be left unplugged?
Old Apr 27, 2011 | 09:00 AM
Coneynew's Avatar
Coneynew
I am not 100% sure if the C/C will work w/ it unplugged, but you may just want to grab that piece from a donor F-Series from a salvage yard. I think you would really want your cruise to 'deactivate' when you hit the brake pedal (if I am understanding what you're saying). Is the switch on your clutch able to be relocated to your 81 brake pedal?
Old Apr 27, 2011 | 09:36 AM
84-6.9L's Avatar
84-6.9L
Try moving the switch from the clutch to the brake pedal. My auto has the brake light switch and the vac dump valve on the brake pedal
Old Apr 27, 2011 | 07:27 PM
hacking_in2002
Relocating shouldn't be a problem for the clutch switch, or I hope not. The donor has both the dump valve,and brake light switch on the brake pedal. I'm just wondering if the auto trucks with CC had the plug for a clutch switch already in the harness. ( In other words, were the Auto and Manual CC harnesses the same?)
Old Apr 27, 2011 | 08:05 PM
Sw1tchfoot's Avatar
Sw1tchfoot
I recall seeing a plug up under in the general area of my brake pedal that is "looped"
I have an Auto with factory installed cruise control. I'll have to take a look at it again.
moosey78
Feb 12, 2016 03:38 PM
booman
Sep 15, 2009 04:09 PM
TommiFIN
Electrical Systems/Wiring
Jun 30, 2008 03:57 AM
thunder82
Dec 31, 2006 09:50 AM
luconn3
Feb 12, 2005 11:11 AM
