emergency
Old Aug 8, 2010 | 06:04 PM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
If the duck bill is on the return line it will be file. What is the capacity of your tank? If it is a 38 gal, then 15" should be the correct measurement, if it is a 30 gal I don't know for sure. You will only suck air in on the suction line.
Old Aug 8, 2010 | 07:11 PM
bulla's Avatar
bulla
Well before I went ahead and dropped the tank today I decided to remove my filter in the valey to watch the fuel flow into the housing. To my suprise there was no air coming into the housing. So then I crawled back under the truck and my racor filter was almost completly full. Yesterday when I was looking at it it was only about half way full. So I think what I was seeing was only the fuel dumping into the half full filter and was making what looked like air coming in to the filter. Does that make sense. I figured if there are no bubbles coming into the housing in the valey then it should be fine. I also bleed the line going to my fuel guage to see if air in the line was making the pressure jump around. The last time I drove it my pressure was right at 58psi and would still drop to 50 under heavy acceleration. The truck still doesnt seem to run any better though.
Old Aug 12, 2010 | 04:23 PM
bulla's Avatar
bulla
These are pics of my homemade umbrella.
Old Aug 12, 2010 | 04:25 PM
bulla's Avatar
bulla
Maybe you can see it better in this pic.
