can you replace piston rings from bottom
Old Aug 6, 2010 | 11:34 PM
jwood2326's Avatar
jwood2326
Got a 95 f150 I6 with a cracked head top of cylinder # 5. bought head from discount installed truck runs but is smoking and fouling #5 with the new head. Assumming the piston rings were damaged when overheated, I want to replace just the rings on #5 without removing the head. has anyone done this? I've tried the non foulers but the spark plug still fouls with runny oil.
Old Aug 6, 2010 | 11:46 PM
Hitokori's Avatar
Hitokori
no nononononononono piston gas to come threw the top
Old Aug 7, 2010 | 12:16 AM
85e150's Avatar
85e150
Check the valve seals first.
See any room to pull the pistons out the bottom?
http://crank-scrapers.com/ford%20300%20installed.jpg
Old Aug 7, 2010 | 12:27 AM
White 97 xlt's Avatar
White 97 xlt
Sorry,, ain't gonna happen!!!!
Old Aug 7, 2010 | 12:31 AM
danger-ranger93's Avatar
danger-ranger93
good luck pullin from the bottom, i dont think the best magician could pull that one off lol
Old Aug 7, 2010 | 12:40 AM
Hitokori's Avatar
Hitokori
no u can get it out the bottom by removing the crank... but u wont get it back in that way
Old Aug 7, 2010 | 12:46 AM
danger-ranger93
true...didnt use my nogin on that'in
Old Aug 7, 2010 | 04:17 AM
chillmiller's Avatar
chillmiller
just pull the head man i mean while your at it pull the whole shabang out and do em all hell if ya got some cash to throw around go and get them holes punched 20 over /shave the head down and slap it all back together with a cam and some roller rockers
i think id be pretty cool + ya pick up some power mpg and 19 internets
Old Aug 7, 2010 | 08:43 AM
jwood2326's Avatar
jwood2326
So it looks like a no go on the rings
The head is new , so the valve stem is very unlikely. could the excessive heat that hurt the first head around the #5 cylinder have hurt the injector to also cuasing a fouled plug. how much oil could possibly get past the ring. when the head was being replaced i checked the top of the piston wiggle test seeing if there was play between the piston and cylinder. all pistons were tight. could a bad injector cuase alot smoke. blueish grey.
Old Aug 7, 2010 | 11:39 AM
Ohio Ford Farm's Avatar
Ohio Ford Farm
A compression test will tell you if your rings are bad with out having to pull no more then the spark plug. Don't forget unless the motor is very new you can not replace rings with out honing the cylinder first.... would be pretty hard to do with the head on.
Old Aug 7, 2010 | 11:45 AM
Hitokori's Avatar
Hitokori
If the injector was flooding it it would be black smoke like a diesel... but oil will cause a bluesh smoke like from a 2 cycle engine... bad rings will also cause excesive blow by
jetmon135
Jul 14, 2013 12:43 PM
rolape2
Apr 2, 2011 11:13 PM
Mikes92F250
18
Jan 28, 2008 07:30 PM
90f150moneypit
17
Sep 23, 2003 11:02 PM
webby
Oct 22, 2000 11:15 PM
