Duraspark FAQ
Old Feb 13, 2003 | 09:13 PM
2speed's Avatar
2speed
Duraspark FAQ
Is there a duraspark FAQ anywhere?
Lot's a sites have the conversion info but I've seen some discrepencies....
What's the difference between Duraspark I, II, and III?
The distributor is good to 6000 rpm, but the stock module I've read gets flaky at 3500, and is worthless over 4500?
I've read it's not very tolerant of low voltage situations, is this true?
Can it be hooked up to an old style coil (I know you don't get all the gains) to make a stock look?
Old Feb 14, 2003 | 07:34 PM
Mike W's Avatar
Mike W
Duraspark FAQ
Someone on the site has the different wiring diagrams available, can't remember his name. The one with the blue grommet is the one to get. I don't buy the rpm limitations. I use one on my distributor machine running at 6 volts to trigger the strobe coil.
Old Feb 15, 2003 | 06:01 PM
Franklin2's Avatar
Franklin2
Duraspark FAQ
The duraspark II is the one everybody favors, with the blue grommet like the other poster said.
The duraspark II has a vacuum advance, and centrifugal advance weights underneath the breaker plate.
The duraspark III is for use with a computer system. It has no way to advance the timing. It basically sends pulses to the computer, which modifies it for timing, and the modified signal is sent to the duraspark III module. You don't want this unit.
I don't know what a duraspark I is. If I where to guess, it may be an early version without the dura II improvements.
Old Feb 16, 2003 | 02:30 AM
airharley's Avatar
airharley
Duraspark FAQ
http://www.jason.fletcher.net/tech/d.../duraspark.htm
This site gives the ins and outs of tuning your duraspark system. Plus how to wire it for proper operation. Hope this helps.
http://home.cfl.rr.com/mustangsix/Engine/duraspark.htm
http://meb.bronco.com/techinfo/mods/...duraspark.html
https://www.ford-trucks.com/user_gal...?&albumid=1232
And last but not least a special thanks to Barry Bucks for our own site. Thanks Barry!
Old Feb 17, 2003 | 09:31 AM
2speed's Avatar
2speed
Duraspark FAQ
There was some good info in that last site, thanks.
Ok, I've done more research and I've read Duraspark is good to about 5000rpm before it gets flaky.
Now more questions....
Blue - standard
Yellow - Economy/Altitude adjustment
Red - Automatic dwell
Ok, the yellow one may seem a little more to hook up for whatever benefits it may add to mpg, but the red one seems like the ticket, yet all those duraspark conversion web sites say to use the blue one. Why?
Old Feb 17, 2003 | 10:06 PM
Mike W's Avatar
Mike W
Duraspark FAQ
Where did you find the info about the red and yellow? Thanks
Old Feb 18, 2003 | 01:42 PM
2speed's Avatar
2speed
Duraspark FAQ
In the last link of the post of links, the one that's on this site. If you go through all the wiring diagrams, there's a brief description of the changes through the years.
I wish someone would put together a complete info sheet on all the Duraspark incarnations, I would, but I can't find the info!
wiseguy
15
Jun 12, 2015 12:43 AM
SVTDriver97
Feb 20, 2014 12:01 PM
62fordF250
May 26, 2010 09:44 AM
XolieX
Aug 19, 2009 10:21 PM
stroker393
Electrical Systems/Wiring
Apr 20, 2009 02:37 PM
