just another ? 4 engine experts please
Old Aug 5, 2010 | 02:48 PM
r23k4u1968's Avatar
r23k4u1968
all this is Rob again and numberdummy helped out a lot and if he is here or anyone with exp. it is evident i dont!!
1. I am trying to copy and paste it but it is labeled 9685 on the 1970 ford truck 302 in one of the forms but it doesnt give name just 9685.
It is a hard like metal or vaccum hose like from near back of carb but not attached to it, and it goes right into the header it looks like. but if you get this picture and it is bottom engine, 9685.
anyhelp would be appreciated please!!
rob
Hi
Old Aug 5, 2010 | 02:49 PM
r23k4u1968's Avatar
r23k4u1968
re:also
it has a hard like cloth wrapped around the hose like thing and it broke off from header part
Old Aug 5, 2010 | 03:22 PM
rattler12's Avatar
rattler12
Does it connect to a spacer between the carb and intake manifold? Sounds like it might be a preheat connection from exhaust manifold to intake to help with cold engine starts until the it all warms up
Old Aug 5, 2010 | 03:33 PM
r23k4u1968's Avatar
r23k4u1968
ratler
yes it does, is that what you said it was?
Old Aug 5, 2010 | 04:09 PM
rattler12's Avatar
rattler12
I am an expert by no means but I believe that's what it is...maybe one of the other guys can verify.... and the number in the picture for the part is 9865 not 9685. I looked for 9685 until my eyes crossed. But then again 9A603 performs a similar function warming up intake air during warm up
Old Aug 5, 2010 | 07:07 PM
Ford_Six's Avatar
Ford_Six
9A603 is the warm air riser, it connects to the lower port on the air filter snorkel to provide warmer air in cold weather.
The piece marked 9865 is for the hot air choke. Air flows from a port under the round part of the carb, down through a coil in the exhaust manifold, and is drawn back up into the choke housing to warm the spring and release the choke. Later systems warmed the spring electrically.
Old Aug 6, 2010 | 04:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by r23k4u1968
I am trying to copy and paste it but it is labeled 9685 on the 1970 ford truck 302 in one of the forms but it doesn't give name just 9685.
It is a hard like metal or vacuum hose
The illustrations (which I deleted) in this post are from the 1964/72 Ford Truck Parts Catalog / Illustration Section 60, Page 19.
The basic Ford part number is 9865 and it is not a steel or copper tube or a vacuum line.
9865 is only the insulator (C8WZ9865B) that covers the tube (choke stove). It was available by itself or came in a kit that also consisted of the tube (furnished with the kit only) and fittings.
The following is what you are asking about:
C8OZ9819D .. Thermostatic Choke Control Outlet Tube Kit / Fits: 1968/72 F100 302 & 1968/72 289/302 Passenger Cars / Obsolete
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-272-8762. No Ford Dealer, no other obsolete parts vendor has any.
Old Aug 6, 2010 | 03:55 PM
r23k4u1968's Avatar
r23k4u1968
numberdummy
YOU ARE BY FAR NO NUMBER DUMMY!!! THANKS MY MINDFREAK!! HAHA!! YOUR AWESOME
rlauer
Vehicles for Sale
Jul 31, 2015 07:38 PM
rlpatte
Mar 27, 2015 10:45 AM
Biggoomba
1947 and Older Ford Trucks
41
Nov 27, 2013 07:07 PM
EXv10
Dec 5, 2012 08:23 PM
mig25
Jan 6, 2012 10:41 PM
