Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Tune-Up Time!!
Old May 22, 2010 | 08:39 AM
CavsFan's Avatar
CavsFan
Tune-Up Time!!
Leaving now to go to Advance Auto to pick up the items for my tune-up. Motorcraft spark plugs, intake gaskets, & PCV Valve. Question is, on some of the pictures I have of a V6 Escape pcv valve, I see a tube that a hose attaches to that is "V" shaped around the PCV Valve. What is that tube for? and why is 1 PCV Valve offered with the "V" tube and 1 does not have the "V" tube? I'm also going to clean the Thrittle body and MAF Sensor. Should be a great day under the hood. Any other suggestions for the tune-up and pm.
Old May 22, 2010 | 12:54 PM
bmuhlbach's Avatar
bmuhlbach
follow the how to change your Escape sparkplug thread on here its pretty easy need a big wrench for the egr other then that check your vacuum lines.
Old May 31, 2010 | 10:39 PM
CavsFan's Avatar
CavsFan
All went well with the tune-up. I changed spark plugs, lower and upper intake gaskets, PCV Valve, checked the torque on the valve cover gaskets, cleaned the throttle body, idle air control valve, and Mass Air Flow sensor. I inspected all the vacuum lines and EGR components. Air filter was changed and oil 7 filter changed and replaced. The Escape runs like new money. Only thing that happened was I broke the clip that holds the hood bar when the hood is closed. All in all it wasn't a bad experience. The best advice I can give is take your time, follow the Haynes manual and/or instructions from this forum and it will go well. Take care to check all the hoses as you are putting things back together. The job took me about 4 hours including the filter changes and all the cleaning I did.
Old Aug 16, 2010 | 06:47 PM
rockos3354's Avatar
rockos3354
Hood Prop Rod support clip
They have the clips at Advance Auto Parts made by Dorman part number 45396 $5.29 it has six different style clips in box and one to fit your escape.
Old Aug 17, 2010 | 05:06 PM
tcesni's Avatar
tcesni
"I broke the clip that holds the hood bar when the hood is closed"
I've done the same thing.
fixnair
Apr 25, 2013 07:18 PM
jmcdaniel05
Aug 22, 2011 08:40 PM
tralfamadorian
May 10, 2009 06:22 PM
Bonebraker
Feb 19, 2007 05:46 PM
shckwavrdr
1978 - 1996 Big Bronco
Aug 17, 2003 05:14 PM
