Knocking sound when stopping
Old Aug 5, 2010 | 07:25 AM
ArtVnTampa's Avatar
ArtVnTampa
Lately my 05 F-250 6.0 SD has been making a knocking sound when I stop. It only happens maybe 2-3 times a day and it occurs as I'm coming to a complete stop. It doesn't occur when I slam on the brakes but rather, when the brake is applied slowly. Any help is greatly appreciated! Thank you!! ArtV
Old Aug 5, 2010 | 07:47 AM
bismic's Avatar
bismic
Just to get some background -
What oil and brand filter are you using?
What fuel filters are you using?
How often do you change the oil and the fuel filters?
Any lack-of-power problems?
Has your fuel economy dropped?
Is it an engine knocking sound, a gurgling sound, or what (be as specific as possible)
Does it do it when the engine is hot, cold or doesn't matter?
Can you check to see if there are any codes (DTC's)?
BTW - you can have codes without the CEL on.
Old Aug 5, 2010 | 08:42 AM
ArtVnTampa's Avatar
ArtVnTampa
Bismic
What oil and brand filter are you using? Rotella oil and motorcraft filter
What fuel filters are you using? International fuel filters
How often do you change the oil and the fuel filters? I change the oil every 6000 miles. I bought the truck with 31,000 miles and I changed the fuel filters @ about 60,000 it now has 82,000
Any lack-of-power problems? No I have not felt any.
Has your fuel economy dropped?I never got anymore than like 14.2 MPG
Is it an engine knocking sound, a gurgling sound, or what (be as specific as possible) Its not an engine knocking (I dont think) it almost feels as if I hit a pothole or ran over a speed bump.
Does it do it when the engine is hot, cold or doesn't matter? Doesn't matter. I've never changed the brakes and my front ones are starting to squeal. Could that have something to do with it??
Can you check to see if there are any codes (DTC's)? Don't know much about codes or how to get them...
Thanks for your help Bismic!!
<!-- / message --><!-- sig -->
Old Aug 5, 2010 | 09:59 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Have a look at this LINK. This may or maynot be your problem, but worth looking at.
Old Aug 5, 2010 | 10:03 AM
bismic's Avatar
bismic
Thats what I was thinking also!
Old Aug 5, 2010 | 10:17 AM
69cj's Avatar
69cj
I would also try using the blue marine grade grease. It is water proof and has tiny fibers in it that would help the cushioning effect. I also would try drilling and installing a mini zerk fitting.
Old Aug 5, 2010 | 11:44 AM
ArtVnTampa's Avatar
ArtVnTampa
Thank you!
Thanks for your help guys, its greatly appreciated!! I will check it out!!
AV
96sherm
27
May 21, 2021 08:17 PM
Fords & Whalers
Jun 29, 2017 09:59 PM
bdlesch
2009 - 2014 F150
Nov 2, 2015 06:35 PM
offshore1
2009 - 2014 F150
Mar 29, 2014 02:44 PM
Ranger256
Escape & Escape Hybrid
Dec 30, 2005 01:41 PM
