hedman headers
Old Aug 3, 2010 | 05:04 PM
johnson2007's Avatar
johnson2007
hedman headers
im looking at putting hedman 89218 headers that are jet-hot coated on my 1979 f150 4wd with a 400. does anyone know the dimensions of these headers or have pics so i know what kind of issues i will have with the crossmember and how far down the headers will hang? any help is greatly appreciated. thanks
Old Aug 3, 2010 | 08:06 PM
bigfoot22's Avatar
bigfoot22
I put a set on my '74 F-100,2WD. with no issues what so ever.I purchased mine from Summit.
I got the black ones along with the Flowmasters and wished I had went with the coated Heddmans.
Just did'nt have the cash at the time.
Maybe you can call Heddman and see what they say about your set up.
Old Aug 3, 2010 | 08:47 PM
johnson2007
when i called them before, all they had mentioned was that you couldn't install them with a dana60 front axle. i have a dana40 so that's not a problem. i have heard before of the cross member issues, however, and i have also heard of not being able to use these headers with the dual shock setup which i have. i was just looking for input from people that have used them. thanks again
Old Aug 3, 2010 | 11:56 PM
HIO Silver's Avatar
HIO Silver
Hedman Hedders Info
I'm providing the all the info for 4WD Dents so you all can share with other members as the need arises.
Source: 2008-09 Heddman Hedders Catalog
Tel: 562.921.0404
Fax: 562.921.7515
Email: sales@hedman.com
Applicability:
4WD 1/2 & 3/4 ton pickup, F-150, F-250, F-350 (Light Duty Only)
Years: 65-76
Engines: 352-390
Headers:
Painted - PN 89120
HTC Coated - PN 89126
Elite or Stainless - PN 89830
Applications:
A/C - Yes
P/S - Yes
Transmissions:
Automatic Column Shift - Yes
Automatic Floor Shift - Yes
Standard Column Shift - Yes
Standard Floor Shift - Yes
Footnotes: 4, 6, 138, 166 (3/4 - 1 ton only)
4 = Includes parts necessary to retain emission devices (50-state)
6 = Modify stock exhaust to retain catalytic converter
138 = Will not fit Camper Special or vehicles with front sway bar
166 = Will not fit multi-shock absorbers, factory of aftermarket installations.
Emissions: C, G
C= For vehicles 1964 through 1974 without A.I.R. systems, considered as O.E.M. replacement parts when existing emission controls are not removed from vehicle.
G= 1975-1976 only, 50-state legal for these years only.
Years: 77-79
Engines: 351-400M
Headers:
Painted - PN 89360
HTC Coated - PN 89366
Elite or Stainless - PN 89868
Applications:
A/C - Yes
P/S - Yes
Transmissions:
Footnotes: 6, 41, 45
6 = See above
41 = Fenderwell exit
45 = Not legal for sale or use in California on pollution controlled vehicles.
Emissions: B, D
B= Not applicable or intended for street or highway use. Legal only for racing vehicles whichmay never be used upon a highway.
D= Not legal for sale or use in California.
Years: 77.5-79
Engines: 351-400M
Headers:
Painted - PN 89210
HTC Coated - PN 89216
Elite or Stainless - PN 89218
Applications:
A/C - Yes
P/S - Yes
Transmissions:
Standard Column Shift - No
Footnotes: 4, 6, 44, 166
4 = See above
6 = See above
44 = Will not fit Dana 60 front differential
166 = See above
Emissions: L
L= 1977-1979 only, 50-state legal for these years
I have the 89120s and they exited dead center on the crossmember. I used a 2.5-inch Jegs Hot Rod exhaust kit and snaked both tubes up and over the crossmember and parallel to the right frame rail.
Oy. Read note 166 for application.
Old Aug 12, 2010 | 05:04 PM
johnson2007
so has anybody with the factory dual shock setup in the front ran these?
skeeter1971
Nov 13, 2015 03:01 PM
F-250 restorer
Aug 28, 2015 02:17 PM
73axlenut
Apr 1, 2015 09:15 PM
jim collins
Mar 20, 2014 09:40 AM
Boba Fett
Mar 10, 2013 08:07 AM
