Hedman headers , fit.
Old Mar 18, 2014 | 08:19 AM
jim collins's Avatar
jim collins
Is anybody using "Hedman Headers" #20045 ,for the 5.0 , 302 in the 73 /79 , 2-WD chassis ? If so , how was the fit around the starter , oil filter ,steering gear , ect. ? Are they built good with a 3/8" flange ? I have a 73 with the 302 / AOD trany and in need of headers. The ones I am looking at are sold by "Bronco Graveyard .com" . Thanks JIM
Old Mar 18, 2014 | 10:10 AM
hivoltj's Avatar
hivoltj
I'm running them on a '77 with a 400 2wd and the fit is pretty good. I always suggest getting them uncoated and fitting them before coating. I've had to ruin ceramic headers before to get them to fit.
I heated the tubes on mine a little and used a ratchet strap to pull them away from the tranny about 1/2". The shift linkage was rubbing on the driver's side and I couldn't get to the tranny cooler lines on the passenger's side.
Mine are part # 89260 IIRC
Hedman ELITE headers have the 3/8 flange and 16 gauge tubes, mine are 1/4" flange and 18 gauge
Old Mar 18, 2014 | 01:17 PM
tstone712's Avatar
tstone712
I ran them on my 79 that I no longer have and all was great with them except some interference with the lower steering shaft, a little indent in the primary and it was all good.
Old Mar 18, 2014 | 07:18 PM
meborder's Avatar
meborder
they likely wont clear the starter unless it specifically says it fits an AOD.
i tried it in a crown vic once ... not even close.
best bet would be shorties.....
Old Mar 20, 2014 | 07:04 AM
jim collins
__Thanks, the AOD starter mount was my biggest concern . Do you know the part number for the shorties, i had to go that way on a chevy street rod once. I never liked them as well as the longer tube , but what ever works is the way i will go.__
Old Mar 20, 2014 | 09:40 AM
meborder's Avatar
meborder
http://www.summitracing.com/search/d...r-style/shorty
can't speak to fitment on shorties, as i've never used them, but i would think this is your best bet. you can probably tell by pictures if it is going to be close or not
MyName1sMud
18
Sep 29, 2013 09:12 PM
SoupCan™
Jan 13, 2010 09:28 PM
Jeremy LeLacheur
1966 - 1977 Early Broncos
Apr 19, 2009 11:40 AM
Jeff
Jul 16, 2005 07:08 PM
MIKE 351
Aug 9, 2002 10:43 PM
