Bronco II Ford Bronco II
clutch package
Old Aug 3, 2010 | 02:47 PM
mudslinging79's Avatar
mudslinging79
clutch package
need part numbers for a heavy duty cluth for a 87 b-2 2.9 with the fm-146 tranny, would one from the ranger 4.0 work? i do a lot of pulling a boat and need something that will last longer than the stock clutch disk setup
Old Aug 4, 2010 | 11:36 AM
country0001's Avatar
country0001
I know it'll work if u have the M5OD, not sure bout the Mitsu
Old Aug 4, 2010 | 02:05 PM
HappyJack's Avatar
HappyJack
It has been posted and tech articles writen on the 4.0 clutch up grade on other sites. The indication is that the trans bell housings with an internal slave will all work. But as with most stuff your on your own when doing mods. The early TK trans bell housing with the external slave has been said to be too small to accept the larger 4.0 clutch and preasure plate and flywheel. The later TK and FM with internal slave are said to work.
Robs89wag
General Diesel Discussion
Jan 17, 2017 07:36 PM
GAHIGHRIDER
Apr 20, 2016 08:50 AM
lowtrkn2k
27
Aug 12, 2015 06:20 AM
GAnderton
1983 - 2012 Ranger & B-Series
Oct 16, 2006 08:50 PM
Boltgunner
Jul 12, 2005 10:18 AM
