Clutch slave line replacement
Old Oct 16, 2006 | 05:25 PM
GAnderton's Avatar
GAnderton
I am doing a 5.0 conversion on my 01 ranger 2.5, and i need to replace the clutch slave line does anyone know how to remove the plastic line from the brass fitting on the pedel assembly?
Old Oct 16, 2006 | 07:58 PM
agryphon's Avatar
agryphon
The line is held in the master cylinder by a small roll pin. You prob are going to have to remove the master cyl to get the line out of it.
Old Oct 16, 2006 | 08:50 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
I just replaced a Clutch master cylinder on my Ranger. The inner fender liner needs to be removed to get at it easily. I used a punch that was the same size as the roll pin in the master cylinder and just used hand pressure to push it out. After you remove the roll pin the line will just pull right out. It can be done without removing the master cylinder.
templars
Sep 14, 2019 07:42 PM
dconrads
Jan 8, 2015 09:32 PM
projectdagger
Sep 6, 2013 01:31 PM
1179
Aug 31, 2006 07:03 PM
