5.0 gt40 heads
Old Aug 3, 2010 | 01:46 PM
aubreydavis0416's Avatar
aubreydavis0416
5.0 gt40 heads
What will i have to have to install gt40 heads on my 87 f-150 4x4, 4 speed manual?
Old Aug 3, 2010 | 04:59 PM
Conanski's Avatar
Conanski
A lot of machine work.. because heads don't normally mount on a transmission.
Old Aug 3, 2010 | 09:02 PM
Conanski's Avatar
Conanski
Obviously I'm being a wiseguy, but it's for good reason because you didn't specify what motor you're putting the heads on(5.0 or 5.8) or what motor they came off.. and it makes a difference in both cases.
Old Aug 4, 2010 | 07:13 AM
aubreydavis0416
302 or 5.0
They are going on a efi 5.0. In the title it says 5.0 gt40 heads. I was just stating that i had a 4 speed manual.
Old Aug 4, 2010 | 07:27 AM
Conanski's Avatar
Conanski
So in your case if those heads came off a 5.0 motor then it's a simple bolt on no changes necessary, but if they came off a 351 then the bolt holes will be larger and you'll need a set of head bolts with a 1/2" diameter collar at the top. For reference the 5.0 motor uses 7/16" head bolts while the 5.8 uses 1/2".
Old Aug 4, 2010 | 08:05 AM
aubreydavis0416
thank you
yes they are off a 5.0 so thank you very much. Will i have to use new head bolts as an upgrade or will the stockers be fine?
Old Aug 4, 2010 | 08:45 AM
Conanski's Avatar
Conanski
Stock bolts are fine as these motors do not use torque-to-yield head bolts.
James Patrick Harris
Jun 6, 2013 05:18 AM
deve
Sep 15, 2011 08:53 AM
jaye
Aug 8, 2011 06:07 PM
lmd91343
16
May 19, 2008 10:35 AM
spidermonkey
19
May 11, 2008 02:16 AM
