I have a 1992 F150 5.0 4x4 as of right now. I currently have obtained a 1998 Mercury Mountineer which has the 5.0 GT40 heads. All I want to do is use the GT40 heads on my f150. I've seen a few threads but none specifically to mine.
There is nothing specific in this swap actually, the F-150 up to 1996 had the E7 heads, which are the same you have right now, so you can use any F-150 E7 --> GT40 swap thread as a guide for your procedure.
Double check those heads; if you have a '98 Mountaineer engine, I believe you have the GT40P heads and not the GT40 heads. GT40P Heads require some finessing to get headers/manifolds set up properly.
GT40P heads require either the FRPP shorty headers (or any one that is advertised to work with P heads) or you can run 90 degree spark plug wires and you MIGHT have to do a little bending on cylinders 4 and 5's exhaust tubes.
