I am wanting to have a spray in bed liner done to my truck. I have had friends who got Line-X installed at a local shop and they're happy with it. It doesn't seem to fade much and they give a lifetime warranty. So that is who I plan to use unless you can suggest a better alternative.
My big question is, should I have it done over the rails or not? I have the stock plastic pieces over the rails and tailgate now. It would be cheaper to leave the plastic in place, but I can't decide if it would look better with the liner over the edges instead.
Also, does anybody know if they pull / cover all the bed bolts before they spray? In other words, if I have to remove the bed after the liner is sprayed, will I be able to easily?
i would remove the plastic caps and spray over the edge. i would think the caps could trap water under them and cause rust issues over time. this is on my list of things to do also. they will spray over the bed bolts unless you tell them other wise. you can take a box knife and cut around the bolt if you do need to get them out. i had my old truck done at the line x in raytown, my friend has had several done and each time they did a great job.
Mine was already sprayed when I got the truck, they sprayed over the bolts. i just cut them out with a razor knife when I had to lift the bed for a goose neck install. They left the plastic rails on mine and did just the inside of the bed. My Tacoma has it over the rails, and I like it. Being in MO, I would think rust would be the big concern, might pull the plastic and go over the rail with it for that reason more than any other.
Pull the plastic, That stuff is tough stuff. You can then load from the side and not have to worry about scratching your rails. Plus if you gotta stand on the rails you wont fall as easy as you would with the plastic. I personally think it would look better. If I do mine, thats the route ill be goin.
Plastic ones are junky. Things slide around easily and it rubs the paint off of the bed where it touches. One of these day's I'm gonna gather up some cash and head to the Line-X guy to have him repair my off brand spray in liner that came with the truck and have him do the over the rail coating.
For an example of how tough this stuff is, I had a 100 gallon transfer covered in Line-X. When I slid it out of the truck after getting it done, the corner of it almost rubbed through the plastic on top of the tail gate and gave me one hell of a brush burn. I even drug it across some rough concrete without scratching it.
I thought the plastic that covers the sides and top of the tailgate has a bunch of holes under it for them to snap in. What would you do with all the holes?
Excellent question. I haven't tried removing them yet so I wasn't even sure how they were attached.
There are more than a dozen holes down the top of the bedsides under the plastic rails. They are also pretty uneven, it would require welding the holes up and doing some bodywork to get the tops straight. I'll get a picture of my 'spare' bed and try to post it tomorrow, I was really surprised when I saw what it looks like without the plastic. Pretty bad when you can't take those cheap crappy plastic rails off to get it sprayed. The tailgate is almost as bad.
Exaclty. The plastic rails snap into place. If you remove them, you'll have to cover them up with something. You could have them spray over the plastic rails, but you need to leave them in place since there are no replacement options other than stock I've seen.
After 100,000 or 200,000 or 300,000 etc. miles on our trucks I would suspect that there will be a need to have some kind of body work done. I'm all for leaving the stock plastic caps on and just spraying inside the bed. And IF the plastic caps wear some paint off or cause a bit of rust have it fixed.
My truck came with a bed line by Arma... I've never heard of them before, if I had to do my own I wouldn't use them. I would go with Line-X. They seem to be the leader of the pack.
I used RhinoLiner Rhino Linings
Very happy with it. No slip. I have spilt oil, dergreaser, carry my tools. No scratches, stains or marks. If you want to sell the truck they can touch it up and have it looking like new.
