View Poll Results: liner inside only or over the edges?
Keep the stock plastic in place
33.33%
Remove plastic and spray liner over the edges
20
66.67%
Voters: 30. You may not vote on this poll
bed liner opinions?
Old Aug 4, 2010 | 08:15 AM
Justin03PSD's Avatar
Justin03PSD
Originally Posted by Shade
There are more than a dozen holes down the top of the bedsides under the plastic rails. They are also pretty uneven, it would require welding the holes up and doing some bodywork to get the tops straight. I'll get a picture of my 'spare' bed and try to post it tomorrow, I was really surprised when I saw what it looks like without the plastic. Pretty bad when you can't take those cheap crappy plastic rails off to get it sprayed. The tailgate is almost as bad.
Well it sounds like my hand is pretty much forced. That sucks.
I'd still like to see the pictures, though. Thanks for your input.
Old Aug 4, 2010 | 10:14 AM
mikeyc0120's Avatar
mikeyc0120
Justin - something I did was pulled the liner out, sprayed it up to the rail and replaced the plastic rails with diamond plate chrome rails. Looks sweet as hell! I've also tinted my liner with the base coat of the paint I painted the truck with so it matches.
Old Aug 4, 2010 | 10:20 AM
Justin03PSD
I might be interested in those chrome diamond plate rail covers. Where'd you get 'em?
Old Aug 4, 2010 | 12:59 PM
twags6's Avatar
twags6
You might want to ask the Line-X guy what he does in those situations. I'm sure we're not the only truck that have holes like that. If they're small, I'm thinking they can simply spray over the gap with no problems. The stuff goes on 1/4" thick IIRC, so it should bridge over a decent hole without an issue.
Old Aug 4, 2010 | 03:40 PM
mikeyc0120's Avatar
mikeyc0120
Believe it or not EBAY. They have 2 types, ones that replace the plastic rails and ones that cover then. I replaced them. Theyre only about 30 bucks. The matching tailgate cover is on backorder so waitin on that still.
Old Aug 6, 2010 | 02:46 PM
Justin03PSD
If you can post a link or give me a company name that would be great. The only ones I've been able to find are the style that stick on top of the stock plastic with double sided tape. That seems pretty cheesy to me; if they don't clip in at the stock locations I don't want 'em.
Old Aug 6, 2010 | 02:50 PM
Justin03PSD
Small update for everybody... I traded emails with the shop earlier this week, and called this afternoon to make an appointment. They gave me quotes for under and over the rails, then immediately followed with "the plastic rail covers are not made to be removed". So that reinforces the notion that the only real option is under the rails.
The appointment is Wednesday the 25th. The under-rail price is $419. I'll be sure to post pictures after it's all done. He also said they remove the bed bolts, so I won't have to cut them back out afterward.
Old Aug 6, 2010 | 03:05 PM
mikeyc0120's Avatar
mikeyc0120
Sorry I missed this post. I have the stick on ones. But I riveted them on the inside of the rail too. I don't know if you're going to find any that mount in the factory holes.
Old Aug 6, 2010 | 03:07 PM
redfire42's Avatar
redfire42
I have the Rhino liner and love it. Nothing slides on it and is softer the the liner-X IMO. Sprayed over bed bolts but not the tail gate bolts. Makes it easer to get in a lub or whatever the tail gate handle. I have one cut in mine where they TRIED to slide a pallet of pellets in when I told them it wouldn't slide.
Old Aug 6, 2010 | 03:08 PM
Justin03PSD
No problem, and thanks for the clarification.
chesster51
Feb 10, 2015 01:27 AM
MDSuperDuty
Nov 17, 2013 09:04 PM
Cobra330
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Jan 19, 2006 02:33 PM
mrsr71
Apr 3, 2004 11:45 PM
Screwchief
2004 - 2008 F150
Feb 1, 2004 12:22 PM
