Locking Hub
Old Aug 3, 2010 | 01:00 AM
Mydiesel250's Avatar
Mydiesel250
Locking Hub
Hey, got a jammed front left locking hub. I can barely turn it with pliers, not a chance by hand. Any advice?
Old Aug 3, 2010 | 01:27 AM
F350JOHN's Avatar
F350JOHN
Post
It sounds like there could be debris in your hub grooves...
Pictures are from member afreemanmd:
Old Aug 3, 2010 | 05:43 AM
shacks87's Avatar
shacks87
Steve you could try this http://guzzle.rbmicro.com/allube.html
My stock hubs were shot so I put Warn hubs on mine. Hope this helps.
Old Aug 3, 2010 | 08:50 AM
Mydiesel250
I can turn it with a wrench and everything functions, is there a way to access the inside and lube somthing up? I really cant afford any new hubs. I removed the locker and all the splines look clean, I can get locked splines to spine freely if i push my fiknger to the bottom of the inside of the locker. It seems like i just need to pull everything apart and clear it out? Any ideas on that process? Im going to check this link out meanwhile, Thanks for the help!
Old Aug 3, 2010 | 11:57 AM
riverrat41's Avatar
riverrat41
^^^Look just above at Shacks87's post.....Read Guzzles great write up
ZBIGBIG19TH
WTB - Parts & other
Dec 11, 2009 11:11 AM
fordf350crazy
Mar 26, 2009 03:41 PM
forddriver17
Jan 18, 2009 05:29 PM
jaxf250
Jan 9, 2003 10:10 AM
martin63
1997 - 2003 F150
Jan 22, 2001 09:20 PM
