evaporator core removal?
Old Jul 27, 2010 | 05:06 PM
empiretc's Avatar
empiretc
Question evaporator core removal?
over a year ago, my a/c system started leaking. I have been adding a can as needed, but it is time to take care of it.
I went ahead and had my buddy order the complete system so I can replace everything. The condenser, accumulator, compressor and lines are all pretty straight forward.
My concerns are the evaporator coil. Has anyone ever replaced/removed it? Any information is greatly appreciated.
Old Jul 27, 2010 | 05:23 PM
Orezona's Avatar
Orezona
No help here, but, welcome man. Haven't seen you on here in a looong time.
Old Jul 27, 2010 | 05:35 PM
empiretc's Avatar
empiretc
yeah, i lurk when i can, but work and a growing family has kept me busy. it's still good to stop in when i can.
i have replaced a few before in different f**ds, and they were all a major PITA. just hope someone here can give me some pointers.
Old Jul 27, 2010 | 07:35 PM
Kwikkordead's Avatar
Kwikkordead
My guess is the dashboard has to come off and the climate control assembly come out on the bench so you can swap it out.
Old Jul 27, 2010 | 08:52 PM
mueckster's Avatar
mueckster
Disconnect the battery ground cable.
Disconnect the condenser to evaporator line spring lock coupling.
Discard the O-ring seals.
Remove the suction accumulator/drier. For additional information, refer to Suction Accumulator in this section.
Remove the nuts and reposition the manifold absolute pressure sensor and bracket (7.3L diesel).
Remove the nuts and reposition the vapor management valve and bracket (5.4L and 6.8L).
Loosen the clamps and remove the intercooler tube (7.3L diesel).
Remove the screws and remove the evaporator core housing support bracket.
Remove the 11 screws, release the 3 retaining tabs and remove the evaporator core cover.
Remove the evaporator core.
To install, reverse the removal procedure.
Install new O-ring seals lubricated in clean PAG oil.
Lubricate the refrigerant system with the correct amount of clean PAG oil. For additional information, refer to Section 412-00 .
Evacuate, leak test and charge the A/C system. For additional information, refer to Section 412-00 .
Copy and Pasted from my Ford Manual on DVD. Fairly straightforward job.
Old Jul 27, 2010 | 10:30 PM
empiretc's Avatar
empiretc
hey, thanks Roland. That $20 manual i have was not as detailed. I like that they always say "reverse the removal procedure". It looked like it would come out from the engine side. Glad it does.
my dad is going to do the job for me as I do not have the time and he could use the extra cash.
Were there any diagrams? The old man likes pictures.
Old Jul 27, 2010 | 10:47 PM
mueckster's Avatar
mueckster
I'll see if I can post a few.
Old Jul 27, 2010 | 10:55 PM
empiretc's Avatar
empiretc
cool, or if you need to, you can send it to me directly in pdf or something. thanks again.
Old Jul 27, 2010 | 10:56 PM
mueckster's Avatar
mueckster
Name:  evap core removal.gif
Name:  evap core removal 2.gif
Name:  evap core removal 3.gif
There are a couple more, but these should help explain the cover removal.
Old Jul 27, 2010 | 11:00 PM
empiretc's Avatar
empiretc
this is great. it will definitely help a lot.
Old Jul 27, 2010 | 11:04 PM
mueckster's Avatar
mueckster
No problem. Glad to help.
Old Aug 3, 2010 | 01:07 PM
empiretc's Avatar
empiretc
suspicions were confirmed, the evaporator was leaking. It was a very slow leak, but you could clearly see the spot where the leak was.
11 years on the original core- not bad I guess. It was about 1/2 plugged with lint and junk.
So now I have a perfectly good compressor, drier, condenser and lines sitting in the shop. Anyone need an a/c system???, lol.
vpschex
Mar 2, 2024 09:45 AM
jerrylynnb
1983 - 2012 Ranger & B-Series
Oct 20, 2009 07:03 AM
meck1
Aug 11, 2009 09:57 PM
Mornel
Aug 4, 2008 04:42 AM
gottaGTO2
Mar 20, 2004 12:56 AM
