loose steering
Old Aug 2, 2010 | 10:01 PM
lamenytro's Avatar
lamenytro
loose steering
i drive a 1990 f150 and its got the loosest steering, i have at least a 1/4 turn of play, and i was just wondering if i have to replace the whole steering column or just replace something.
Old Aug 3, 2010 | 01:50 AM
TexasGuy001's Avatar
TexasGuy001
That couuld be any number of things. It could be worn tie rod ends and/or a worn steering box. These are my guesses.
Old Aug 3, 2010 | 08:56 PM
cpettymore7777's Avatar
cpettymore7777
check your tie rods like texasguy said. there maybe a load screw on the steering box and you can tighten it a turn or 2. also the joint in the steering shaft may have play.
Old Aug 3, 2010 | 10:06 PM
fishforlife2007's Avatar
fishforlife2007
yes check the tre's..other than that the main culprit for it is gunna be the gearbox...the worm gear inside of it wears and just about 95% of the older model ford trucks out there have a little bit of play because of it. mines pretty worn but ill ride it out for a little bit longer....
Old Aug 4, 2010 | 09:35 AM
tjc transport's Avatar
tjc transport
i ain't rite
have someone sit in the truck and turn the wheel back and forth while you look at the connector point on the steering column in the engine bay where the upper column meets the lower column for play. there is a teflon bushing that is held in place by a spring steel clip. if the clip breaks, the bushing will fall out, leaving you with about 1/4 turn play in the steering.
Old Aug 4, 2010 | 01:54 PM
jplinville's Avatar
jplinville
Go no more than a 1/8-1/4 turn at a time on the adjustment screw...the worm gear is easy to screw up!!!!
seagiant
16
May 22, 2024 01:57 AM
creedua
19
Jun 11, 2014 01:01 PM
76BIG/ORANGE
Mar 14, 2014 04:13 PM
bikeymikey
Dec 15, 2012 07:30 PM
0351mike
1966 - 1977 Early Broncos
Aug 8, 2011 09:36 PM
