Starter - Won't Start Spinning--Won't Stop Spinning
When I try to start the truck sometimes the starter won't stop spinning. I have to take the battery cable off to stop it. And sometimes it won't do anything when I try to start it and have to jump across the solenoid to start it. I have replaced the solenoid and still the same thing. I thinking a bad ignition switch? Truck is an 88 F150 4x4.
You could well be right about the ign switch. It is on top of the steering column under the dash.
However it could also be a problem with the linkage connecting the key switch to the ign switch.
There is a two piece cowl around the steering column right where it meets the dash, take this off (two screws). You will now see the rod that connects the key switch to the ign switch.
Lift a battery terminal off. Put your finger on the rod and then turn the key round to the start position and back to off. The rod should move in "time" with the key. If it does then most likely you have a bad ign switch.
If it does not then most likely the pot metal ign actuator in the column is broken.
First off always a good idea to lift off the neg battery terminal then just unplug the ign switch, unbolt it and disconnect it from the rod coming from the key switch and you are done.
When replacing it you may need to leave the two bolts slghtly loose so that you can slide the switch up or down the column a little to get it properly adjusted.
jmuenchow
11-10-2016 10:48 AM
bill06447
13
01-03-2016 02:20 PM
Greg Castro
1999 to 2016 Super Duty
03-10-2012 06:39 PM
