Strange problem
Old Aug 7, 2010 | 01:56 PM
bduemig's Avatar
bduemig
No The sensor will be changed on Monday. As soon as I accelerate above idle, the tach works and OD light stops blinking. No shifting problems.
Old Aug 7, 2010 | 03:44 PM
Dave Sponaugle's Avatar
Dave Sponaugle
bduemig,
The throttle position sensor is only for the transmission, no effect at all on the engine.
For the engine to cut out with a mechanical govenor, about all it could be is the govenor sticking when small fuel rate differences are needed.
My first move there would be pull the fuel filter, drain it and refill with Diesel Kleen.
The start the engine and let it run for 15 seconds and shut it down.
Now let it sit for a couple hours or the next day if possible.
The Diesel Kleen will clean out deposits and lubricate the IP linkages while it soaks.
When you do start it up again, take it out and run it on the hard side for a few miles with a few hard accelerations mixed in with your driving.
With a little luck, your problem will be gone.
Old Aug 9, 2010 | 07:30 PM
bduemig's Avatar
bduemig
Problem solved. Turned out to be the tach sensor after all. It appears the overdrive was trying to kick it because the tach wasn't accurate. As soo as the tach sensor was changed, problem went away!
wareagle8403
Jan 7, 2012 08:09 AM
turbill
Sep 21, 2010 05:43 PM
shawneeriverjams
Jul 11, 2009 09:11 AM
magilla
Feb 1, 2007 11:23 AM
joe denney
Oct 24, 2005 04:08 PM
