removing a levelling kit?
Old Aug 2, 2010 | 08:14 AM
Nader's Avatar
Nader
This is a 2000 F350 4WD. Prior owner made the truck all pretty with some cosmetic upgrades, including a front levelling kit that looks like a mini spring pack. I'm actually putting the truck to use, and don't like having the nose pointed up in the air when the bed is loaded down.
Since I wasn't the one who installed this lift, I'm not sure what's involved in removing it. Is there anything more than just removing the spring packs? Any other bits need adjustment or compensation? Thanks.
Old Aug 2, 2010 | 10:23 AM
megawatt00's Avatar
megawatt00
Remove the spring pack and use new u bolts and you are good to go.
Old Aug 2, 2010 | 12:16 PM
farmb0y's Avatar
farmb0y
What do you want for the spring pack?? How many inches is it?
Other way to go is put some airbags on the back on. Keeps things level and rides so much better.
Rockindoc
Aug 21, 2021 09:21 PM
jonnydz
Aug 29, 2013 08:56 PM
m0nkee221
Aug 7, 2012 08:55 AM
a77bronc
Dec 23, 2009 10:33 AM
