Power Brakes
Old Aug 1, 2010 | 09:57 AM
Kevin In MN's Avatar
Kevin In MN
Power Brakes
1960 F100 Custom Cab
What is an economical way to add power brake to my original manual drum brake set up? With the clutch master cylinder there isn't much room.
Old Aug 1, 2010 | 12:08 PM
55f100tx's Avatar
55f100tx
i would look under the hood of a 90 to 93 ford pickup they also used a clutch master cyl. on the firewall. could be other years also, but those years i owned at one time or another. i always thought it was a nice setup.
Old Aug 1, 2010 | 04:30 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
There is a seller on Ebay who regularly has a set-up which includes a reduced-size power brake booster/dual chamber master cylinder and it has a "spacer"that extends the unit out from the firewall,to miss the clutch master cylinder.I'ts designed for our 57-60 trucks,but is a bit ugly,and if you're a purist,probably won't satisfy you.He even has them in all chrome occasionally.Steve.
Old Aug 1, 2010 | 04:35 PM
VI661959's Avatar
VI661959
LMCTruck sells power brake assemblies as well I believe.
DeLaine
Jun 3, 2021 01:41 PM
abe
Mar 6, 2014 07:22 AM
wvbogger
Jan 31, 2008 01:09 PM
karlsd
May 25, 2002 12:14 AM
tetraruby
Sep 23, 2001 06:00 PM
