Brakes
Old Apr 2, 2014 | 08:15 PM
DeLaine's Avatar
DeLaine
Brakes
My brakes are being funky sometimes no power, next time may be fine and vice-versa. Brake booster?
Old Apr 2, 2014 | 08:41 PM
Talyn's Avatar
Talyn
Could be vacuum, break booster or air in the lines.
If the rear drums are out of adjustment, that can cause an issue as well.
Old Apr 3, 2014 | 12:55 AM
madpogue's Avatar
madpogue
Do your HVAC controls work okay?
Old Apr 3, 2014 | 07:42 AM
mjunk1's Avatar
mjunk1
Are you getting a light on the dash? Might want to add year and model as well. Little more info would go a long way with the experts on here (not me).
Old Apr 5, 2014 | 11:02 AM
DeLaine's Avatar
DeLaine
1995 F350 powerstroke
I need brakes. Started making noise thursday so i am going to start there. Thank for everyones help. If this doesnt fix the issue i will be back...lol
Old Jun 3, 2021 | 01:41 PM
Yendra Built's Avatar
Yendra Built
Booster / Hydrovac
When your going down the road there is vacuum on both sides of the diaphragm in the booster, when you apply the brakes the atmospheric valve allows atmospheric pressure to go to one side of diaphragm increasing brake pressure. If there’s a hole in the diaphragm it’s a giant vacuum leak. There could be a Bendix ID tag on the booster.
four-sixty-power
May 8, 2016 10:39 AM
Sw1tchfoot
22
Nov 19, 2011 10:05 PM
beermonger
1978 - 1996 Big Bronco
Oct 24, 2010 09:24 PM
f100help
Sep 2, 2010 08:39 AM
Big Red
May 10, 2006 09:52 PM
