Morning Lee!! I bet seeing that tornado was quite a sight! As long as it wasn't close to your house!
That is great that you can make it! We are planning on leaving here about 12-12:30 and it will take a couple hours to get there I suppose.
It was actually very close to home, and would have only missed it by .5 miles at the most, but it was very very weak, barely broke any small tree branches.
I was thinking on leaving work early on Friday, but if I bring the 5er to work with me it is only 10 miles to the CG.
Wow Lee that was a little close. Seeing it out in a field would like you said would be a little more comfortable!! I think Mike has friday off and will also be there early so he may see this and confirm. Lee you look like you are gonna have the shortest drive but don't I get an award for the longest drive! Lol
Originally Posted by DieselCamper01
If I am counting correctly you would make six. (that's 2 x 3)
myself
Tom
Troy
Dave
Mike
you
Did I miss anyone?
I think that is everyone! Your multiplication also seems to be correct this morning!!
You know, I have not. I suspect it is too late to do much with it. Something just feels funny the last few time driving. I was going to get that bed liner and doing 70 on the interstate and my temps hit 170.
I wonder if I could hook my scan gauge up to your truck and check the trans temp with that, or being an 01, did you not have a factory trans temps sensor?
My computer is too stupid to give that info Lee. I do have two seperate guages hooked up to two different sensors. They do read different temps but they were both climbing that day. Granted it was over 90 out too but that seems high running unloaded and no topper either.
I would like someone else to drive this thing and see what they think
My V10 will run about 80 over ambient empty before my new cooler, now it is about 70 over.
When I towed my 5er to Canada I was about 90-100 over in OD and 100 - 120 over in D and that is with the additional Hayden cooler. I did see temps up to 220 when pulling a 10% grade for 6 miles, and it was only 60 out.
