Carb question?
Old Aug 1, 2010 | 02:17 AM
WarDog65's Avatar
WarDog65
Carb question?
Will a Holly 600 be to big for 240? Will be doing P&P, larger valves, offy c intake, EFI exhaust manifold, Thanks
Old Aug 1, 2010 | 02:24 AM
Rogue_Wulff's Avatar
Rogue_Wulff
It's more than needed, but will work fine with proper tuning. If you're looking at buying new, I'd consider a holley 390 or 465, or an edelbrock 500. If buying used at a decent price, or already own the holley 600, then by all means, it's worth trying.
Old Aug 1, 2010 | 02:35 AM
WarDog65's Avatar
WarDog65
Its on ebay rebuilt for 145....was also looking at an autolite 4100 would have to be rebuilt
Old Aug 1, 2010 | 08:04 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
As long as it's not mechanical secondary it should be okay.
Old Aug 1, 2010 | 09:23 AM
WarDog65's Avatar
WarDog65
It is a vacuum secondary, I know by reading on here that the 240/300 doesn't create enough vacuum for a 600cfm???, if that so woould adding a vacuum canister work?
Old Aug 1, 2010 | 10:50 AM
Harte3's Avatar
Harte3
https://www.ford-trucks.com/forums/9...n-it-work.html
Your question is basically answered in that thread.
"...reading on here that the 240/300 doesn't create enough vacuum for a 600cfm???" Where did you read that?
I'm just guessing at what you are talking about but the vacuum canisters you mention are for high performance engines with long duration and wide overlap cams...the cams cause the drop in manifold pressure (vacuum) and vacuum operated devices like brake boosters won't operate properly without sufficient vacuum thus the canisters to "store" the vacuum.
Holley's eBay store/auction will list the 1848/465cfm 4v carb from time to time.
Old Aug 1, 2010 | 03:00 PM
Rogue_Wulff
The 240/300 doesn't create the vacuum needed to operate the secondaries of a 600 CFM carb until well over 3500 RPM. There's really nothing you can do to change this, as the vacuum used to operate the secondaries is created by airflow thru the primaries. When the primaries start getting near peak flow, they create vacuum inside the internal port that feeds the vacuum motor that opens the secondaries. This system works rather well, since it only opens the secondaries as needed, and then opens them only as much as needed, while maintaining peak velocity inside the primaries.
You see, it doesn't matter what type of engine the carb is sitting on, the secondaries will not open until the primaries reach near-peak velocity.
Also, it doesn't matter whether the engine makes much (if any) manifold vacuum at idle. It's not manifold vacuum that operates the vacuum secondaries. They are opened by "Venturi Vacuum", which is directly related to the volume of air flowing thru the venturi(s) of the carb.
Old Aug 3, 2010 | 01:31 AM
F-250 restorer's Avatar
F-250 restorer
The 4100 came in two sizes. The 1.08 venturi size (stamped on float bowl), which is 480 cfm, and the more common 1.12 venturi, which is 600 cfm. Either one is more than 40 years old! If you get it cheap--and I mean for about $50--then I'd say give it a whirl. The 480 cfm works great.
However, because of Pony Carbs, and all the mustang oem restorations, the price on replacement parts is high. If you are unsure, I'd say to go with a carb that is MUCH newer, and therefore less likely to have issues.
Old Aug 3, 2010 | 10:48 AM
91Bronc300's Avatar
91Bronc300
The annular boosters used in the primaries of the autolite 4100 or in some of the holley carbs makes a significantly stronger booster vacuum for a given airflow through a given venturi bore size. You can use larger carbs withouth detriment to low end trottle response. For a carb that uses straight leg or dog leg boosters 600 CFM is probably too large for a street driven 240 IMO. I personally feel that the Holley 390 is too small for 300 inch motor, but for a hopped up 240 I would seriously consider it.
awillo0406
20
May 7, 2013 02:58 PM
MiamiPSD
Feb 6, 2013 05:08 PM
sneak
Jan 24, 2006 09:09 PM
Ultramagdan
1997 - 2003 F150
13
Jun 27, 2005 10:10 PM
