Transmission Shift Points / Full Throttle
Old Jul 31, 2010 | 11:18 PM
stf26's Avatar
stf26
Hey Guys on my 6.7 I have opened it up a few times from the line and noticed that the engine does not rev past 3000 rpms when it shifts to 2nd. Is this what everyone else sees? With a red line of 4000 rpms I would think that the shift from 1st to 2nd would be closer to the redline of the motor. Just curious.
Old Aug 1, 2010 | 12:38 AM
adamtheman16's Avatar
adamtheman16
Redline is never usually near the torque curve of the engine. If its a dragster, then more-so yes, but a diesel, no.
The torque curve is probably just below 3000 RPM, that wy it pulls to 3000, then shifts back into the beginning of the torque curve so you don't loose the torque in the next gear.
Is there a spec that tells you what max HP and max torque are at specific RPM's? Like a sticker on the engine somewhere?
Old Aug 1, 2010 | 01:41 AM
kper05's Avatar
kper05
My understanding is max torque is at 1,600 RPM and max HP at 2,800 RPM.
Old Aug 1, 2010 | 08:49 AM
EpicCowlick's Avatar
EpicCowlick
That's correct. There is no point in revving past 3,000 because the power curves are going in the wrong direct. Personally, I have been amazed at how the truck keeps the rpms in the perfect position when I need them. Pulling hard it stays nicely right at the peak power output all by itself. No need to manage on my part.
Old Aug 1, 2010 | 12:28 PM
rdenis's Avatar
rdenis
Yep this tranny is slicker than slick - definiteley an engineering marvel.
Old Aug 1, 2010 | 12:30 PM
stf26's Avatar
stf26
Thanks guys for the feedback.
Old Aug 1, 2010 | 09:53 PM
rickatic's Avatar
rickatic
6800 miles and the smile gets bigger every mile. I love the new transmission
waystro
Jul 26, 2014 12:29 AM
jayro88
Jun 8, 2014 08:43 AM
illini community
Feb 28, 2014 09:59 AM
az4x4bronc
Apr 8, 2007 10:50 PM
Crazyromi
1978 - 1996 Big Bronco
Oct 13, 2003 12:49 PM
