400 valve noise
Old Jul 31, 2010 | 10:57 AM
jerm111's Avatar
jerm111
400 valve noise
so i have a 400 in my vehicle and when i get going 50 mph or faster something starts making a noise it almost sounds to me like a chatter/knock type noise. it sounds like it is coming from the valves to me. can anyone give me any advice on where to start as to diagnosing this problem?
Old Jul 31, 2010 | 10:22 PM
Furyus1's Avatar
Furyus1
Does it get worse after it warms up?
Have you checked for exhaust leaks?
How long has it been doing this?
Old Aug 1, 2010 | 10:55 AM
jerm111's Avatar
jerm111
uh yeah actually it does get a little worse once its warmed up. i have kinda checked for exhaust leaks. not really examined but just gave it a quick look over didnt see anything out of the ordinary. um i bought the motor on june 26th and it has been doing it ever since i got it. the oil is really thin and im doing an oil change this week if that would make a difference.
Old Aug 1, 2010 | 02:20 PM
Furyus1's Avatar
Furyus1
Could be any number of things... An exhaust leak makes that kind of sound and it will get worse when the engine is warmed up...
Could be valvetrain - lifter preload, rocker clearance, etc... The 400 has a non-adjustable valvetrain so, any kind of wear or clearance issues will be noticeable.
Mine started making a slight "ticking" noise after I swapped the heads - finally figured out it's from the rockers hitting the valves - it's not terribly bad - more of a nuisance than anything, but I think doing a rocker stud conversion is somewhere on my to-do list...
Have you narrowed-down where the sound is coming from? Down low or up high? Valvetrain is noticeable as you'll hear the ticking from under the valve cover...
Your oil change idea would definitely help - well, couldn't hurt, anyway...
Old Aug 1, 2010 | 08:46 PM
jerm111's Avatar
jerm111
when im driving it sounds like it could be coming from the valve cover cause it has that kinda of echo type sound but im not exactly sure. it doesnt make the noise when im idling even at a high rev it kinda starts to make the noise but not enough to tell what it is.
Old Aug 1, 2010 | 08:47 PM
jerm111's Avatar
jerm111
it only really starts to be loud enough to hear it when i am driving over 50 mph and have moderate throttle on. when i let off the gas the noise gos away
Old Aug 1, 2010 | 10:16 PM
Furyus1's Avatar
Furyus1
I would think valvetrain noise would be more consistent. I would maybe check again for exhaust leaks - just to be sure...
Just a thought, but how's the timing? Maybe what you're hearing is a "pinging"... How do the spark plugs look?
Old Aug 2, 2010 | 07:50 PM
jerm111's Avatar
jerm111
yeah i could check again. i have it timed to 12btdc maybe i can back it down a little to 10 see if that helps. i just changed my plugs the other day.
Old Aug 2, 2010 | 07:51 PM
jerm111's Avatar
jerm111
if i am wrong about where the noise is coming from could it be a rod knock possibly? from what i know if it was it would be consistent not just when im going 50mph or higher. it never makes the noise at any speed lower than 50
Old Aug 2, 2010 | 09:26 PM
Colo79Ford's Avatar
Colo79Ford
Does the noise only happen 'under load"??? If so, check your ignition timing and fuel octane rating... could be possible fuel pre ignition if its not a constant problem and doesnt happen all the time....
Old Aug 3, 2010 | 05:34 PM
jerm111's Avatar
jerm111
im not exactly sure what you mean by under load. it only happens while im giving it gas and at a spd of 50mph or higher. i can be going 45 and give gas and it doesnt make the noise but 50 it does.
Old Aug 5, 2010 | 10:42 AM
mark a.'s Avatar
mark a.
Have you checked all the lifters preload ?
Old Aug 6, 2010 | 10:12 AM
jerm111's Avatar
jerm111
no i actually dont know what that means haha.. how would i go about doing that?
Old Aug 6, 2010 | 11:14 PM
mark a.'s Avatar
mark a.
Get the lifter on the cams base circle and loosen the rocker nut. There should be some preload into the lifter plunger when the rocker nut is tight. You can use a dial indicator or scribe a line from somewhere on the head to the push rod without any preload. Then scribe a line with it tightened down and measure the difference with a machinist scale inbetween the 2 lines. It should be around .020-.040 no more than .060. If there is no preload then you will have a lifter ticking noise.
Old Aug 9, 2010 | 08:20 AM
SoArkSI's Avatar
SoArkSI
my 77 351m motor does the same noise either revving in neutral or underload and giving throttle. It has the same tack hammer on a tin can kinda sound. I am believeing that I may have the same problem.
