speedometer need help
Old 08-01-2010, 07:32 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 65fstback
That is the stock gear for 1948-1960 regular 3 speed ford truck trans.
Uh huh...how many originals have you seen?
There were two types, one was cast iron with an iron gear, the other was steel with a fiber gear.
The plastic gear is an aftermarket replacement.
In 1960, Ford came out with a different design. These driven gears are nylon, look totally different than the earlier gears, are available with 16 thru 21 teeth, are EZ to find...as they are still used today.
The shafts of these gears came in three different lengths. On one of the gears (DOOZ17271A), the shaft is no more than 1/4" long.
The link in post #3 shows one of these 1960 and later gears, and the clip used to retain it.
Old 08-26-2010, 10:24 PM
65fstback's Avatar
65fstback
65fstback is offline
well I glued gear in with J B weld works ok hope it holds Thanks for the help.
Old 10-31-2013, 10:33 AM
helicopterman's Avatar
helicopterman
helicopterman is offline
Hi, I'm having the same problem. It's been some time so, dare I ask, did the JB weld hold?
Old 11-01-2013, 04:51 PM
65fstback's Avatar
65fstback
Still holding give it a try good luck
Old 11-02-2013, 05:05 AM
helicopterman
Thanks, that's great news! At the very end of my cable I used two adjustable wrenches and twisted in opposite directions so as to create an interference fit in the gear, not too much or it will just compress the inner cable. Then I used your method with the jb weld. So far so good.
daveengelson
01-26-2017 03:02 PM
catneck
06-04-2016 05:21 PM
Andy_F100
08-14-2015 09:29 AM
Guhfluh
08-31-2013 06:01 PM
Quick Reply: speedometer need help
