vacuume pump test
Old Jul 30, 2010 | 10:29 PM
mikecwik's Avatar
mikecwik
vacuume pump test
what should i be reading when doing this test. my brake warning light is going on. im guessing i should be reading 17 hg or so. chilton sucks.
92 7.3
Old Jul 31, 2010 | 12:01 AM
87crewdually's Avatar
87crewdually
At sea level you should have 21in hg within 30 seconds at idle. Make sure you have NO leaks. Also the brake fluid resevoir, low vacuum, and parking brake all can make the light come on.
Old Aug 2, 2010 | 06:10 AM
mikecwik's Avatar
mikecwik
it went to 24 hg. i cleaned low vacuum and low fluid connections though they didnt look bad at all. its going to be sitting for a while but i did idle it for a few minutes and the light never came back on. it was only going on when i would sit at a light for a bit so i jumped to the vacuum pump.
thanks for the figures and other info.
Old Aug 2, 2010 | 06:40 AM
Lazy K's Avatar
Lazy K
If the light comes on only when sitting at a light with the brake on then the booster may be bad. Can you hear a hissing sound when you press the brake pedal?
Old Aug 2, 2010 | 10:39 AM
87crewdually
X2. If your holding your foot on the brake and your losing vacuum enough to make the light come on, there is a leak in the booster. Alot of times the master cylinder will also be bad, leaking brake fluid into the booster resulting in eating up the booster diaphram.
Old Aug 2, 2010 | 09:44 PM
mikecwik's Avatar
mikecwik
the truck stops like i assume it should. like i said i played the sitting at the light at idle for a bit and the light didnt come on. ill check the line to the booster and see if i can spot fluid. im not losing fluid. no hiss at idle. i didnt lose vacuum at idle on my guage, that was when the light did come on when i was on the road.
this is one im not sure on. when i step on the brakes at idle. the pedal holds and then falls. brakes work great, probably wouldnt note a thing had the light not popped on.
the truck will sit a few weeks and ill get back here to let you know what happens.
Old Aug 2, 2010 | 11:58 PM
damac's Avatar
damac
our clunker hisses constantly when i am on the brake pedal, is that bad?
i tried to rip all the cruise control stuff out myself and replaced a bunch of hosing when we first got it home. however i found that i would have to pump the pedal like 8 times before the brake light would come on, and it has not come on during normal driving conditions.
Old Aug 3, 2010 | 12:01 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Failed/Failing brake booster ...
Is it bad ... It could be when your brakes become hard to apply when you don't expect it!
-Enjoy
fh : )_~
