dual tank woes
Old Jul 30, 2010 | 08:15 PM
MNbandit's Avatar
MNbandit
dual tank woes
First off I have a 1988 f150 5.0
Recently my trucks been running like crap, alomost like its running out of gas. When it idles it misses and stumbels randomly and when driving it has no power and misses the whole time. Once in awhile it is fine maybe for a few seconds while driving. I know im getting spark and everything.
One thing that puzzles me is that a removed my front tank about a month ago cause it was rusted. But know when I flip from the back to the front tank it still runs! Could this be just the switch on the dash? Or is the tank selector valve thing bad?
Old Jul 30, 2010 | 08:20 PM
broncoderek's Avatar
broncoderek
You may get a lot of "check your fuel filters" replies.
I was thinking that your truck's fuel-lines would have to be used up (when you switch tanks to the non-existant one) for it to stall. It wouldn't die for some distance. There's maybe 5-6 feet of fuel-line filled with gas to use up.
Old Jul 30, 2010 | 08:24 PM
MNbandit's Avatar
MNbandit
I actually replaced my fuel filter about ten minutes ago. Didnt change anything. And I ran the truck with the swith on the front tank for a minute atleast and still didnt die.
Old Jul 31, 2010 | 01:51 PM
broncoderek
It'll take more than a couple of minutes at idle to use up the fuel in the fuel line.
Not sure how long exactly but I'd say 5 minutes at least.
Can you test the fuel pressure?
Old Jul 31, 2010 | 04:44 PM
2007F150FX4's Avatar
2007F150FX4
My 87 F250 460 with dual tanks has a bad rear pump and if I switch from the front to rear tanks it will idle for about 2.5 minutes before it dies.
Old Jul 31, 2010 | 08:24 PM
broncoderek
Isn't that another 3-4 feet of fuel line as opposed to doing the reverse tank switch?
Old Jul 31, 2010 | 08:46 PM
2007F150FX4
I would assume its around that much more fuel line. But either way its going to idle for longer than a minute.
No matter how long it runs on the other tank he still has an issue.
Old Jul 31, 2010 | 10:03 PM
broncoderek
Sorry, I thought you were disagreeing with me in your other post. Yeah, I was thinking 3-5 minutes at idle cutting off the rear tank.
Old Jul 31, 2010 | 10:07 PM
MNbandit's Avatar
MNbandit
Ok ill try running it longer and see if it dies. But it still doesnt explain why it runs so bad. Can the tank selector valve get clogged? I want to get rid of the dual tank stuff and put in a tank from a later model f150 with just the single high pressure in tank pump.
Old Jul 31, 2010 | 10:16 PM
broncoderek
Can you get a fuel pressure reading? When my 94 Bronco did this I tried so many things ($$$) and it ended up being the drivers' side O2 sensor. The codes I was throwing (any codes on your truck btw?) had nothing to do with what was actually wrong. So after like a few hundred dollars of wasted attemps, a $30.00 sensor was to blame.
Old Jul 31, 2010 | 11:10 PM
MNbandit's Avatar
MNbandit
The only code I get is 33 which is the egr opening not deteced I believe. I blocked off the egr though so I don't think it's that. I have replaced the o2 sensor a few weeks ago. I actually replaced the iac and tps sensor also with no luck. I'm not sure of the fuel pressure, I ordered a gauge a few days ago so I should get it soon. I do know both pumps work, I jumped them on the test port and they both ran.
mattb77
Oct 31, 2014 11:56 AM
jzombakis
Jun 21, 2012 09:31 AM
brucers
Aug 26, 2011 07:03 PM
jimandjimmer
Nov 8, 2009 04:45 PM
OneBang
Jun 29, 2005 10:46 PM
