yeah, well i might go ahead and take the cam out and see. It's the only thing in the motor that's not new. it's looked fine when it was out when i rebuilt it. it kinda makes sense, the one night after i had it running really good, the timing jumped back like 20 degrees so i adjusted it back to where it's supppose to be, it's pretty much the last thing to check as of right now. just sucks i have to tear it down again.
yeah, well i might go ahead and take the cam out and see. It's the only thing in the motor that's not new. it's looked fine when it was out when i rebuilt it. it kinda makes sense, the one night after i had it running really good, the timing jumped back like 20 degrees so i adjusted it back to where it's suppose to be, it's pretty much the last thing to check as of right now. just sucks i have to tear it down again.
Could you elaborate a little more on that statement in bold above? Timing does not "jump" on it's own unless something bad happened such as the timing chain jumping a tooth or your distributor has a worn down drive gear or the distributor hold down bolt was loose. How did you check/"turn back" the timing?
i would be really surprised if the chain jumped a tooth, it's new and i just had the timing cover off not to long ago and it was fine. if it would have been a distributor gear the problem wouldn't have carried over to the new distributor. the funny thing is, the hold down bolt was the first thing i checked, but it was tight. i pulled the spout out and checked my timing, so I turned the distributor to 10 btc. that's it.
I'll stick with my original statement. Timing does not jump unless something bad happened. One other thought: the harmonic balancer ring may have slipped. Is it new too? Regardless if it is or not I would check if the pointer is at 0 (zero) degrees when the engine is at TDC.
the balancer is new as well, and yes i have checked it with the pointer and engine. also went and got another balancer to check as well.
Well I have been working on the truck and found a issue. the cam walked on me, broke the retaining ring and with the cam all the way in the lifters wasn't but a 1/4 of the lobes. the cam gear bolt was half way unthreaded. so i pulled the motor cut my losses and put another one in and it runs great.
