6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Does this look like a normal oil check?
Old Jul 30, 2010 | 12:35 AM
StanleyZ's Avatar
StanleyZ
So I'm in Cody Wyoming. It's only 4000 since my last oil change but I'm making oil (see pics) and I'm at 20,000 so I take it to the local dealer and ask them to change oil and filter and fuel filters. I tell thm it's making oil which I have to explain to the service writer. I ask them to fill my sample bottle and tell them don't worry about the high oil level, I will take it up with my dealer when I get home but it would be nice if you could mention the high oil condition just to get it on the record. So, when they have the truck done I get it from a different guy, I pay and ask about my oil sample and he says it's in the truck. It was and as I look a the paper work I note that the tech has written "oil level checks normal. Now here is what the oil looked like on the dip stick about an hour before I took it to the dealer. Am I nuts or are they ? First pic is normal check, second is short stick procedure and third is results of short stick.
Old Jul 30, 2010 | 02:49 AM
Larry NCKS's Avatar
Larry NCKS
It's certainly deeper on the stick than mine with 5000 miles on it. Mine won't come above the fat portion of the stick with it fully inserted.
Old Jul 30, 2010 | 05:12 AM
senix's Avatar
senix
mine comes to about the top portion as well. I just got back last nite. I will check mine this morning.
Stanley, was that motor cold when you did the check?
That is about the only way I get an accurate reading.
Old Jul 30, 2010 | 08:20 AM
dwilliamsceg's Avatar
dwilliamsceg
That looks overfull but it may be within some internal spec. I had a very good tech tell me that he has seen over 20 quarts come out of work trucks. So a quart here/there is not (in his words) too big of an issue. What he did say was that Ford was recommending changing based upon hours and not miles.
Not to take this off subject but what is the point of the short stick method?
Old Jul 30, 2010 | 08:23 AM
sdetweil's Avatar
sdetweil
they needed to give the customer an 'exact' spot to measure to.. (without shipping new parts to everyone) and with short stick its very easy.. set the edge on the tube, pull and read, if its at the full line, then there is a problem.
(above that is too full!)..
Sam
Old Aug 2, 2010 | 08:39 AM
dwilliamsceg
Sam
Gotcha. Is there a TSB or official Ford guidance on the short stick procedure?
There are two pet peeves on my truck. One is that the dipstick is very hard to read and two is that my manual tranny only has two cup holders. Oh, and the cup holders it does have seem to not fit anything correctly except for a soda can.
Old Aug 2, 2010 | 02:21 PM
ChargersFanInCO's Avatar
ChargersFanInCO
No, it doesn't look normal. Mine is at the top of the diamonds after a FULL stick. It was like that at 7500 miles and before the first oil change. I'm over 9000 now, and it's still there. It's halfway up on a "short stick"
Old Aug 2, 2010 | 08:15 PM
ssharber's Avatar
ssharber
Hey Stanley, mine looks just like yours on all pics.
Old Aug 2, 2010 | 09:58 PM
sdetweil's Avatar
sdetweil
can't help with the cup holders
https://www.ford-trucks.com/forums/8...ml#post7189293
sam
Old Aug 3, 2010 | 12:11 AM
Heavysledz's Avatar
Heavysledz
are most people thst are seeing the high oil readings driving 08's.....curious to see how many 09's and 2010's are also seeing this.
Old Aug 4, 2010 | 12:47 AM
Tater Mash's Avatar
Tater Mash
Mine looked like that and I have an 08. They changed the high pressure injector pump which was leaking fuel into the oil.
Old Aug 4, 2010 | 11:50 AM
Heavysledz's Avatar
Heavysledz
Have you seen any issues since they canged out the HP fuel pump?
creich68
2009 - 2014 F150
Feb 18, 2013 06:13 PM
boulderbronco
Apr 4, 2011 08:37 PM
adambomb
Bio-diesel, Propane & Alternative Diesel Engine Fuels
23
Jul 9, 2008 09:38 AM
PowerstrokeJunkie
Jul 24, 2007 08:04 AM
Heckler
Sep 17, 2004 10:30 AM
