High Idle Mod ???
Old Mar 4, 2015 | 07:13 PM
  #31
LiftedBlackHD's Avatar
LiftedBlackHD
My high idle mod used to work. Can't get it to work anymore not sure why.
Old Apr 25, 2015 | 02:01 PM
  #32
tacticalmedic469's Avatar
tacticalmedic469
I got a dumb question.....My wht/blu goes to my throttle pedal control.????
It all works cuz I got the PTO/H.I. lt.bl/ylw near E-brake. Just a question. Any thoughts? Could this be the supplied wht/blu and my other end is burried in the loom?
I do not see any other wht/blu wires near my OBDII?
Old Apr 25, 2015 | 02:15 PM
  #33
jswartz84's Avatar
jswartz84
Mine was labeled PTO, and was in a group of wires behind the CJB next to the e brake.
Are you saying yours is all hooked up and working correctly? The throttle, brake, and e brake will all stop the the high idle function.
Old Apr 27, 2015 | 03:34 PM
  #34
tacticalmedic469
Yeah I found the "REAL" wht/lt.blu wire, boy I got lucky! I was looking above OBDII. I have the blu/ylw stripe(04) hooked to an LED switch, power is needed to energize the LED and the PTO wire, a ground is also needed. But what function does the wht/lt.blu wire serve then? Does it complete the circuit acting as both a ground (via chass. grnd), and comms with PCM? Because if I hook up a ground wire... high idle works, if I hook up the wht/lt.blu... the high idle works. I have a late '04 build and from what I've read on here my high idle should now be right. I'm not much in the electrical dept. but I'm learning fast. I can wire driving lights, repair most OE stuff, I'm great with soldering, just lacking in the use of the meters and understanding the tech side of electrics.
But yeah, it all works and I put and in-line 15 amp fuse! Thanks for reply.
Old Apr 30, 2015 | 06:49 PM
  #35
bobv60's Avatar
bobv60
Thanks for this post. Still learn'n about these Fords. I had 2 gn/yw wits at the e brake On my 2003. Connected them yoga ther and it's working now, but only after its warmed up.
Old Oct 9, 2016 | 03:24 PM
  #36
Fuzzpuss's Avatar
Fuzzpuss
Originally Posted by 11jjonn
Did the wiring and/or colors change between Early 2003 and later (2003.5) models?
My 02-13-2003 does not look like this.
I found the "blunt end" white/blue 12v wire near the OBD-II -- but the "blunt end" wires behind the fuse panel are the following colors:
Solid Blue - solid Red - solid White - solid Black -- all approx 16gauge.
Solid Yellow - Dark Green/Yellow - Light Green/White - White/Orange -- all approx 20gauge.
I was hoping to connect the 12v wire to the SEIC wire, and just use the E-brake pedal as activation switch (as some have claimed to have done).
It's possible my 2003.0 is Pre-SEIC, and needs an APCM (AIC) like the 7.3's.
Any Early (Jan-May) '03 owners accomplish this mod? If so, how/which wires/etc?
The stubs behind the fuse panel on my March 2003 are as follows:
Yellow/white - Dark blue/green - Light Green/White - White/Orange -- all approx 20gauge.
Guess I'll try the dark blue/green and see what happens.
Old Oct 10, 2016 | 12:41 AM
  #37
87crewdually's Avatar
87crewdually
High Idle Mod
F250SDPowerStroke
Jan 26, 2019 10:43 PM
Mike Butcher
Mar 18, 2017 09:23 AM
Offshore530
Dec 10, 2016 12:33 AM
goose_ss4
Jun 28, 2016 01:59 PM
TRIMMAN98
Mar 28, 2016 03:59 PM
