97 E150 5.4 Vacuum question
Old Jul 28, 2010 | 03:49 PM
psd444's Avatar
psd444
Hi guys, great forum! My wifes E150 has 3 hard vacuum hoses running down the passenger side of the engine to 3 hard lines on the frame. 2 of the lines were disconected and the 3rd came loose while reaching in to get the other 2 loose ones. The connections were all brittle. Now that I know why the engine is running like crap, does anyone know the order of these lines? 2 are yellow. I think they are the vapor management valve (VMV) vacuum hoses. Any direction anyone can offer will be greatly appreciated!
Kevin
P.S. The van has 225,000+ miles!!!
Old Aug 6, 2010 | 10:54 AM
chrismcdad's Avatar
chrismcdad
I have a feeling my '02 is quite different.
Try an internet image search for your engine - you may get lucky.
Old Aug 9, 2010 | 08:49 AM
JWA's Avatar
JWA
Almost regardless what the hoses are now if they're cracked and in need of replacing I'd do that ASAP. In fact I'd begin checking every other vacuum hose and replace them as well. Time alone will degrade them under the hood with that much heat.
These things rely upon so much interconnected and cross functional dependent almost anything anywhere can cause some sort of problem.
I believe the '97's are a bit different from the '98s and up---I found this out several times by assuming close in years meant compatibilty with various parts and system components!
87oldtimer
Jun 3, 2014 06:02 PM
Cowboy9215
Mar 17, 2014 05:12 PM
mshefty
20
Oct 22, 2013 02:58 AM
kevbits
17
Aug 7, 2008 01:01 PM
KJKozak2
Apr 18, 2002 12:13 AM
