external engine balance
Old Jul 28, 2010 | 03:21 PM
tater_51's Avatar
tater_51
OK, I received the longblock (410FE) and it came with a flexplate and aftermarket neutral balancer. When I switch to a flywheel (428/410) for manual tranmission do I need to have a rebalance or just bolt on and go? The engine has all new internals and has been balanced but with the flexplate. Any help appreciated. Thanks
Old Jul 28, 2010 | 05:37 PM
mikeo0o0o0's Avatar
mikeo0o0o0
It's never a bad idea to balance everything as an assembly. But seeing as this is a new rebuild, as long as the original specs were used, you should be okay with bolting on the stick flywheel. Factory 410/428's used a counterweighted flywheel and a neutral balanced harmonic balancer.
Old Jul 28, 2010 | 06:40 PM
tater_51's Avatar
tater_51
I was hoping that would be OK. The shop I purchased this from included the work sheet with all the numbers for the balance. Everything is fresh and assembled (new pistons, overbore, crank polished, rods resized, etc. etc.) Would seem a pity to have to tear it all back down to switch over to the flywheel. Thanks for responding.
Old Jul 28, 2010 | 07:57 PM
monsterbaby's Avatar
monsterbaby
look at your flexplate carefully. I lot of lazy shops will balance by welding or drilling on the flexplate/flywheel and the dampener (this is not the proper way but it's the lazy and cheap way of doing it and a LOT and I do mean a LOT of small shops pull this stunt)
If you see where weight has been added to the flexplate then you have a lazy shop and A. never take any work to them again, and B. you will need to have it rebalanced.
Old Jul 28, 2010 | 08:20 PM
OrangeJuice's Avatar
OrangeJuice
What is the proper way of balancing a flexplate or dampener by not welding or drilling?
OJ
Old Jul 28, 2010 | 08:25 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
OJ
A proper balance involves:
Weight matching ALL pistons with pins
Weight matching rods, total weight plus each end.
Zero balance flexplate/flywheel
Zero balance balancer
Spin balance crank, balancer, flexplate with weight bobs to represent rods/pistons
Then drill the crank throws or drill and fill with mallory for a NEUTRAL balance.
Most shops would say screw that and just throw the crank, balancer and flexplate on the machine and then drill away.
Josh
Old Jul 28, 2010 | 08:38 PM
tater_51's Avatar
tater_51
The balance card shows, piston, piston pin, piston rings, pin locks, total rod, insert, rotary, reciprocating and bob weight, all in grams. It makes no reference to crankshaft, balancer/flexplate. This was done on a Hines Microcomputer Balancer.
Old Jul 28, 2010 | 08:55 PM
Bullitt390's Avatar
Bullitt390
Hmmm... they would have had to do something with the crankshaft if they totalled bob-weight.
Does the flexplate look drilled?
It should look similar to the flexplates listed at 428Cobrajet...
428 Cobra Jet Flexplate Identification
Old Jul 28, 2010 | 09:14 PM
tater_51's Avatar
tater_51
Flexplate looks identical with exception of the triangular cut outs. Same part number (FOR-C6SP-6375-A-Assy), looks like weight covers 21 teeth on the flexplate. I see no new weight or signs of it being drilled (other than the two drill holes on the weight).
Old Jul 28, 2010 | 09:17 PM
tater_51's Avatar
tater_51
Oops, there are several (7) smaller drill marks to the right of the weight.
Old Jul 28, 2010 | 10:27 PM
Bullitt390's Avatar
Bullitt390
Do the holes look like newly drilled holes?
If they did drill on the flexplate you may have to completely disassemble the engine to have the rotating assembly balanced with a flywheel.
Josh
Old Jul 28, 2010 | 10:40 PM
tater_51's Avatar
tater_51
Yea, I think I'm screwed. I have yet to pick up a flywheel. Can a shop check the balance (or imbalance) on the flexplate vs. flywheel to see if there is a difference in weight, etc. something like match balancing? If the weights were different than it would be obvious, need to rebalance the assembly.
Old Jul 28, 2010 | 10:43 PM
Bullitt390's Avatar
Bullitt390
I suppose it is possible, and without more knowledge on the process, I would be leary to go that route.
But checking some highly recommended machine shops in your area would net you the best answers.
Josh
Old Jul 28, 2010 | 10:58 PM
montana_highboy's Avatar
montana_highboy
http://www.network54.com/Forum/74182/search
Old Jul 28, 2010 | 11:05 PM
montana_highboy
Hmmm that link's not working for some reason....search "match balancing flywheel" on the FE board i linked to above, there's tons of info on the subject.
