Sponsored by: Auxito
97 signal light problem
Old Jul 28, 2010 | 12:53 PM
lestro's Avatar
lestro
Got a little problem with the signal lights. the left rear and the front right signal lights don't work, however when I turn on the 4 way flashers, they all flash. where do I look?
Old Jul 28, 2010 | 02:13 PM
Podaso's Avatar
Podaso
Sounds like the multi-function switch to me. Take the steering wheel shrouds off and see if the connection is broken/loose.
Old Jul 28, 2010 | 03:16 PM
lestro's Avatar
lestro
I think you're right, I was able to get them working temporarily by working the signal light/dimmer/wiper control around. the truck has been sitting a while.
Old Jul 28, 2010 | 03:43 PM
Podaso's Avatar
Podaso
The steering wheel shroud is simple to get off too. Does your steering wheel tilt/do you use it a lot? If so, that could be another clue leading to the MF switch connection.
1968FordF100
May 28, 2012 05:23 PM
mikeismadness
1978 - 1996 Big Bronco
Apr 11, 2010 12:05 AM
Duke78
Jan 17, 2010 04:58 AM
