Door Glass Install
Old Jul 28, 2010 | 09:39 AM
54TexasF100's Avatar
54TexasF100
Door Glass Install
What is recommended to hold the door glass in window lift channel and the window vent frame? My first thought is the weather strip adheasive but is there something out there that is specific to glass?
Thanks,
Stephen
Old Jul 28, 2010 | 10:37 AM
9teen56f100's Avatar
9teen56f100
Mid-fifty sells "glass seat tape kits" for side and vent windows. 1-800-252-1956. If you have not used mid fifty yet, they are a great to deal with. The ladies there really know there stuff when it comes to these old trucks. Good luck.
brian...
Old Jul 28, 2010 | 11:13 AM
54TexasF100
Thanks Brain. I have not used Mid-Fifty yet. I will look at their parts. I did, however, buy from LMC Truck last month the door channel lift rubber. It is a single side adheasive cork type thick tape that can be cut to length. This did not seem permanent enough for glass applications.
Thanks,
Stephen
Old Jul 28, 2010 | 03:46 PM
52 Merc's Avatar
52 Merc
Stephen, the glass setting tape is all that's used for that application. It's a friction fit and is a permenant as you want it to be. Give it a try before you decide it won't work. Chances are you'll need to be a bit forceful to get it together, so if taking a hammer (or rubber mallet) to glass makes you squeemish, you might wish to seek out professional help. If you have any issues with it not doing the job, then it's the material's fault, not the method. Any local auto glass company would have the correct stuff, as well.
Old Jul 28, 2010 | 06:04 PM
himmelberg's Avatar
himmelberg
It's much easier than you think... get the seal at a glass shop. There is really not that much to it.
good luck, himmelberg
Old Jul 29, 2010 | 09:00 AM
dynamic's Avatar
dynamic
x2 on the glass shop. Dont get me wrong I have great luck with Mid-Fifty but you can save the freight by getting from a local glass company!
Redgranite_Yooper
May 23, 2015 08:51 PM
skimtn
13
May 7, 2012 11:23 PM
54TexasF100
Jul 29, 2010 01:13 PM
tom2131968
1978 - 1996 Big Bronco
22
Nov 20, 2004 10:33 AM
Christopher2
Oct 22, 2004 08:13 PM
