Sponsored by: Real Truck
Rear differential.
Old Jul 28, 2010 | 01:30 AM
Kajtek1's Avatar
Kajtek1
Rear differential.
The bearing in my differential blow up taking the gears with it. I searched this section and there is not too much info about the differentials.
From what I learned I do have Dana 80 differential, what suppose to be the best on the market, yet recommends bearings replacement every 150 k miles. It is not cheap job and shop quoted me $4,600.
I shop around and the best deal in the country was $519 for pinion gears and bearings. Add drive-shaft u-joint and supporting bearing, all the cost of towing and my time and it comes pretty costly any way you look at it.
To top it off the main nut need 470 ft-lb torque. I do have big wrenches, but might buy new huge socket.
So for those with high mileage trucks -beware. Mine did it at 240k and since I bought it at 195k, I don't think the bearings were replaced.
For gas powered truck owners -don't worry about this recommendation
Old Jul 28, 2010 | 10:28 AM
JockD's Avatar
JockD
Kajtek1, try asking at shops that repair big truck transmissions and axles. They often have the best pricing and experience, since they cater to owners who use their trucks to make a living. The Dana 80 is at the low end of their range, but there are lots of delivery trucks out there with that axle.
Old Jul 28, 2010 | 11:01 AM
rbaker6336's Avatar
rbaker6336
You can buy a fairly low milage Dana 80 for around $700 to $1000
Old Jul 28, 2010 | 01:06 PM
bpounds's Avatar
bpounds
That's what I would say, and you beat me to it. Salvage yard.
Question is, will an F350 D-80 bolt up to an F450? An F450 diff might be harder to find.
Old Jul 28, 2010 | 01:11 PM
rbaker6336's Avatar
rbaker6336
spring pads and front yoke may be different but easily changed,ratio may be lower on the F450,Normal for an F350 is 4.10
Old Jul 28, 2010 | 01:32 PM
redford's Avatar
redford
FTE Leadership Emeritus
Perhaps a D-80 from an F-350 Chassis Cab might work.
Old Jul 28, 2010 | 05:34 PM
sammy77's Avatar
sammy77
Still I'd keep shopping around $4600.00 should be easy to beat.
Old Jul 28, 2010 | 05:51 PM
99f350sd's Avatar
99f350sd
My 99 had 80k on it when I put the locker in.. The two big bearings were ready to be replaced..Glad I was in there at that time..
Dick
Old Jul 28, 2010 | 10:31 PM
Kajtek1's Avatar
Kajtek1
Maybe in your area. The shop I was towed to first -did locate the high mileage one for $3500.
I am DIY. I bought the best gears with Timken bearings for $519.
Just finished assembly today. Did the driveshaft supporting bearing and u-joint as well.
The 1 7/8" socket cost me $30,althoght if you think you can find this size in your near hardware story -think again. Took me Kragen Auto, than Home Depot and finally NAPA had it. . I had rest of the tools.
It is sweat to think that one day of work saved me $4000 and I know the job is done right.
What worry me is the bearing failure. Last time I had bearing fail on my car was about 30 years ago. Is the Dana design inadequate for the job? The rolls in failed bearing don't show any wear out and are still shiny. Looks like for some reason the cage gave up and let everything loose. The bearing was made in Japan.
Old Jul 28, 2010 | 10:37 PM
99f350sd's Avatar
99f350sd
Many of my rollers were pitted and the other part that hits the rollers was pitted.
How did you get the nut tight enough on the pinion?
Old Jul 28, 2010 | 11:03 PM
Kajtek1's Avatar
Kajtek1
470 lb-ft takes only 8 foot long pipe extension and only 58 pounds on bathroom scale
Holding the yoke was much harder. My big pipe wrench slip few times.
Old Jul 28, 2010 | 11:06 PM
99f350sd's Avatar
99f350sd
Sounds like you are pretty crafty.. Good job.
Dick
Old Jul 29, 2010 | 10:58 PM
Kajtek1's Avatar
Kajtek1
Drove 30 miles today on new gears. The differential temperature was 168F with about 80F outside, so I guess it is not overheating.
Now cross my heart, after the repair not only engine pulls way better, but transmission shifts smoother and brakes are sharper
Old Jul 29, 2010 | 11:11 PM
rbaker6336's Avatar
rbaker6336
I would think a 4 ft pipe would be a lot easier to handle and 116 lb ain't that hard to pull
Old Jul 29, 2010 | 11:52 PM
Kajtek1's Avatar
Kajtek1
Now you are splitting a hair, or rather a pipe
Would I have 4' pipe, I would calculate for the length. Since I had 8 footer I did not see a reason to cut it for few seconds of use.
Anybody has a recommendation for first oil change? Can I do normal 30k (?) interval, or earlier?
I have a Mercedes sedan with 280k on it and to my knowledge still factory oil in differential.
