87-91 Instrument Cluster Question
Old Feb 12, 2003 | 06:06 PM
pcman's Avatar
pcman
I have a question about a the 87-91 instrument cluster with tach. Looking at the back of the cluster there is a small printed circut board on the right hand side that is held on by two torx screws. What does this board do?? Because one of the intrument clusters in my truck doesn't have it while another I bought for parts does.
Thanks..
Old Feb 12, 2003 | 06:13 PM
steve83's Avatar
steve83
Check here - I think it's an emissions/gas mileage/service interval warning lamp circuit. There should be some text etched into the board, or on the film circuit, like each of the gauges has.
Old Sep 19, 2017 | 04:30 PM
Caveman Eric's Avatar
Caveman Eric
Steve83: Are you still on this site? This was posted many years ago but I found d the same thing on the back of my cluster. I located a replacement but it does not have this attached. I hope this image helps.
Anyone else know, in case Steve is not available?
Thanks
Old Sep 20, 2017 | 07:59 AM
jas88's Avatar
jas88
That is to turn on the "Engine" light if oil pressure drops below a certain point on the gauge, or if water temp goes above a certain point. It was an extra warning if you did not happen to be looking at the gauge at the time. It was deleted on the 1991 clusters, but you can add it and it works. I put one on mine just in case.
Old Sep 20, 2017 | 09:18 AM
subford's Avatar
subford
Here is the wiring for it using the 1990 manual:
Old Sep 20, 2017 | 03:07 PM
Caveman Eric
Thank you both! Eric
Brian Ski 44
19
May 31, 2017 06:37 PM
nstueve
29
May 21, 2017 06:28 PM
Gichael
Apr 26, 2017 07:02 PM
f100today
Jul 19, 2016 09:29 AM
Kyle87
16
Mar 16, 2016 09:25 PM
