89 into an 87..
Old Jul 27, 2010 | 07:21 PM
kenjh's Avatar
kenjh
89 into an 87..
swaping my 89 5 speed into my crew cab (87)..the wireing looks different.. but I can figger that out..what I want to do is drop my turbo from my 96 e-350 on her,, what do I need to change or tune ,or modyfie to get it to make it work .. I have exhaust manafolds and the up pipe.. what differance is there to the injector pump??what do I need to watch for??
Old Jul 27, 2010 | 07:26 PM
eraser5's Avatar
eraser5
Interested in the 5 speed swap. I have an 86 with a 4 speed. A 5 speed OD trans would make interstate travel much better.
Old Jul 27, 2010 | 07:38 PM
johnboggs21's Avatar
johnboggs21
a 96 would be a powerstroke, which from what I understand is way different from an IDI turbo. I know pretty much everything has to be custom made for it to work. Theirs a couple rigs running around with pstroke turbos. Its alot of work to make one work on an IDI and the most boost they would make was about 10 psi IIRC.
Old Jul 27, 2010 | 11:33 PM
kenjh's Avatar
kenjh
it a straight swap .everything has bolted up so far..
Old Jul 27, 2010 | 11:35 PM
kenjh's Avatar
kenjh
my 96 is a powerstoke , I am upgrading with a garret ballbearing turbo,and a dpt tuner.won't the stock turbo work on the pre power stoke?
Old Jul 27, 2010 | 11:54 PM
Blueovals&Blacksmoke's Avatar
anything will work its just how well acquainted with a grinder, welder and plasma cutter that will make the difference.
Old Jul 27, 2010 | 11:59 PM
royzell's Avatar
royzell
Short answer, no. Powerstrokes and IDI's really only share displacement. I did it about 6 years ago and all the pipes, drains, etc. had to be fabricated. For the time and expense and grief I could have bought a new IDI specific turbo like a Banks, ATS, Hypermax.
It never worked as well as expected, and maxxed out around 8-10 psi.
Old Jul 28, 2010 | 12:40 AM
kenjh's Avatar
kenjh
the short answer wins ..thank you
Old Jul 28, 2010 | 01:45 AM
well how far did you crank the pump? boost is mostly derrived from how much fuel you are putting into the combustion chamberand how easily it can flow out.
IE: more fuel in, more combustion taking place, bigger volume of gas going out the exhaust.
ive helped. i did most of the work he payed for everything. put a turbo off of a 3126 CAT onto a 7.3, we had rebuilt the engine and made sure it could hold 35-40 lbs of boost. then cranked that bad boy. we had to fine tune it a few times by turning some more screws up there was smoke on upshifts while waiting for it to spool. it was about like putting a 62MM onto a cummins. it wasnt bad. could have been better but it still built 30-35 lbs of boost. we over built the engine for a reason. had one off injectors made to provide proper atomization at those kinds of pressures, sent the pump off to get reworked. and ran a 4 inch down pipe to dual 6 inch stacks.
anything is possible. it just takes more money than other routes.
Old Jul 28, 2010 | 09:32 AM
royzell's Avatar
royzell
Like you say, time and money will do anything. My pump was cranked up, I forget now how much, but enough that I was rolling coal.
To me, It just isn't more efficient than getting the system designed for the job originally.
Old Jul 28, 2010 | 02:51 PM
greywynd's Avatar
greywynd
How'd you get the valley pan to hold that sort of pressure?
Old Jul 28, 2010 | 09:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle
How did you keep the head gaskets in, valley pan in and the exhaust manifolds on it?
I know what I had to do at a machine shop to run mid 20's.
40 PSI make the effective compression ratio 80 to 1.
