Sponsored by: Real Truck
F350 issues...HELP!
Old Jul 27, 2010 | 05:59 PM
dyxie64's Avatar
dyxie64
F350 issues...HELP!
I've been having a lot of problems with my 2000 F350 5.4 V8. When you put it in reverse it gurgles like a diesel, the rpms drop way below 1000, and it just sounds like all power is dying (my alternator and battery are fine). If you just keep your foot on the gas and back up it'll surge backwards on its own WAY faster than you want, but if you take your feet off of everything it stalls out (it's an automatic so I'm pretty sure that shouldn't happen). It's also been giving me problems going down the road where the rpms will go up between 3000 and 5000 but it'll just sit at 30 mph until it finally kicks back and goes. I'm running 93 and have been using fuel injector cleaner and it's not helping. Any advice would be greatly appreciated!
Old Jul 27, 2010 | 06:06 PM
Furian's Avatar
Furian
You Keep What You Kill
How many miles are on the truck? Are you getting any OBD-II codes? It could be a number of issues... fuel filter, COPS, plugs, vacuum lines, etc.
Welcome to FTE!
Old Jul 27, 2010 | 06:17 PM
JIMRSX's Avatar
JIMRSX
how does it run in park or neutral? This might be a trans or torque converter issue?
Old Jul 27, 2010 | 06:53 PM
dyxie64's Avatar
dyxie64
It has 73,700 miles on it and runs fine in neutral and park. There aren't any codes popping up either. I'm hoping it's not a tranny issue...I just got this truck and it's 100 miles over its thousand mile warranty. Figures...
Old Jul 27, 2010 | 08:16 PM
kbodge's Avatar
kbodge
I had a similar problem with my v10 it was the vacum hose that connects from the pcv valve to the in the passenger side valve cover to the manifold. The engine ran fine at idle, but in gear and driving vacum pulled through the hose caused a slit that had worn through from chaffing to open up and caused all kinds of headaches (engine RPM's up/down, sputtering, stalling while in gear, surgine etc..) Just an idea to check.
Old Jul 27, 2010 | 09:01 PM
redford's Avatar
redford
FTE Leadership Emeritus
Check your idle air controller (IAC).
Old Aug 17, 2010 | 05:46 PM
dyxie64's Avatar
dyxie64
Just figured I'd say this so anyone else with these problems knows... my transmission is burnt up. past the point of repair it needs rebuilt. So much for a simple fix.
truckrider814
Jun 15, 2013 09:45 PM
F250Nelius
Modular V10 (6.8l)
Apr 3, 2011 10:08 PM
sealboy84
30
Jul 10, 2010 10:01 AM
kingjoker76
May 26, 2010 04:32 PM
