Totally DEAD!!!
Old Jul 26, 2010 | 08:46 PM
The1999Beast's Avatar
The1999Beast
Totally DEAD!!!
What would completely kill all power from the battery? no dome light, no nothin!!!!! I'm sure a dead short somewhere but is there a relay or something? Driving me nuts trying to find it!
Old Jul 26, 2010 | 08:54 PM
ctubutis's Avatar
ctubutis
- Bad connections at the battery/solenoid or the ground connection at the engine/frame.
- A slow discharge, in what time frame did this battery die? Have you measured the voltage?
Old Jul 27, 2010 | 03:44 PM
79 bronc's Avatar
79 bronc
Did you find the battery battery dead? or does it have full charge?
If the battery is good (full charge) take a look at my recent posts.
I just went trough a no start problem , something very simalar. I never found a short or broken part. The problem (so far) has gone away. I did take off and reseat almost all the major cables and wires in the starting circuit. Checked and reseated all the fuses. I found the (-)battery cable did have some corrosion about 6-8"into the cable. The only thing i didn't test was my key switch.
Old Aug 7, 2010 | 08:38 PM
CABGx3's Avatar
CABGx3
A bad Blower Motor Relay has been known to do this.
Vaya con Dios,
Chuck, CABGx3
Old Aug 7, 2010 | 09:13 PM
Franklin2's Avatar
Franklin2
If you believe you have a drain, you can make sure by getting a testlight and hooking it up like this. Make sure the door is shut and the hood light if you have one is unplugged. If you have a newer truck, make sure the accessory delay relay has timed out.
If the testlight does show a drain, pull each fuse individually and see if you can get the drain to go away. It you can't find it with pulling the fuses, take the wires off the alternator and see if the light goes out.
Old Aug 10, 2010 | 10:48 AM
79 bronc's Avatar
79 bronc
Thanks Franklin2,
I tried that test and turned out ok. What i found was that i had an intermittant battery ground issue. i had some corrosion down the wire, under the pvc coating. I cut back the coating and cleaned the wire. But i guess there was enought residual corrosion to interupt the starting circuit, and create a no-start. I used a grinder on the frame and installed a new ground cable and for good contact. I haven't had any no-start issues in 2 weeks.
Long story short change the battery cables if you see corrosion leaching down under the plastic coating of the wire.
Yahiko
Washington Chapter
21
Apr 19, 2014 10:47 AM
whack&stack
Offroad & 4x4
67
Jun 2, 2011 07:42 PM
bigun72
21
Jun 3, 2007 11:28 AM
02superstroker
Texas Chapter
23
Oct 6, 2004 11:12 PM
RaidersRock
Bronco II
Jan 5, 2002 12:35 PM
