Modular V10 (6.8l)
Fault codes
Old Jul 26, 2010 | 06:11 PM
Pelon562's Avatar
Pelon562
Fault codes
I'm having a problem with my 2000 f350 v10, I've got two fault codes that keep coming back, the first is p0171 and p0174 which both are for system too lean bank 1&2. I'm not sure what "bank" means in this case, I'm really hoping someone has came across this issue or can guide me to some info on how I can eliminate this problem, thanks for your time in advance.
Old Jul 27, 2010 | 11:16 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Bank 1 is the one with cylinder #1 in it. Passenger side bank of cylinders.
Since you're getting BOTH sides lean, I'd look for a vacuum leak. The notorious PCV elbow at the throttle body is known for causing this.
If that's good, I'd check the MAF and see if it's clean. Air getting past the MAF without it reading it correctly will cause lean codes.
Old Jul 27, 2010 | 06:09 PM
Pelon562's Avatar
Pelon562
Ok I'll check it out, thanks brother.
wilbur996
30
Nov 15, 2008 02:13 PM
goodstiff88
Feb 11, 2008 10:47 AM
IM1096
Nov 6, 2007 04:55 PM
motlot77
Jun 14, 2005 08:29 PM
jcoyote
1997 - 2003 F150
Mar 11, 2001 09:05 AM
