Updated STC fitting instructions please.
Old Jul 26, 2010 | 04:40 PM
FSeybert's Avatar
FSeybert
The kit for my updated STC fitting did not come with any instructions. Would someone be so kind as to post or email the installation instructions.
Thanks,
Fred
f_seybert@msn (dot) com
Old Jul 26, 2010 | 06:53 PM
cheezit's Avatar
cheezit
sure.
here it goes. remove pump. remove fitting from pump, install new fitting by screwing it in 5 complete turns. install alignment bracket on to pump with nylon nuts and bolts. tighten fitting. remove alignment bracket and reinstall pump.
if you would like a picture of the pump with the bracket and fitting in place I did post some pics up. check my posts in the search function.
Old Jul 26, 2010 | 08:02 PM
FSeybert's Avatar
FSeybert
Thanks Cheezit. I plan on tearing into the oil cooler replacement next weekend. The 'Big Brown Truck' just dropped off most of the parts. I'll see if I can't find your pictures.
Thanks again,
Fred
Old Jul 29, 2010 | 01:20 AM
Benchwrench's Avatar
Benchwrench
Thanks,
Fred
Where did you get your STC fitting? dealer?
I have an early model 06 that needs the intake removed so I wanted to address all the necessary items while in there.
Thanks for the info.
Old Jul 30, 2010 | 08:44 PM
FSeybert's Avatar
FSeybert
Yes, dealership. The 'parts guy' had no idea what it was. The 'Diesel Tech' came in, knew exactly what I wanted and went and got it off the shelf.
Old Jul 30, 2010 | 08:57 PM
m-chan68's Avatar
m-chan68
Sounds just like my world.
lostru
Oct 8, 2014 07:47 AM
jerkypants
Feb 27, 2012 05:52 PM
rdunagan
Aug 5, 2011 02:07 AM
Hunter,DDS
Mar 21, 2011 11:24 PM
jwheatley20
Jun 19, 2010 11:45 PM
