VIN HELP/ REAR END
Old Jul 26, 2010 | 01:23 PM
mtpcage's Avatar
mtpcage
VIN HELP/ REAR END
I was trying to research the rear endin my truck is the 3.73 standard, It sit a little high , i wouldn't think that would make a differance?
vin 1FTPW14566F
THANKS
Old Jul 26, 2010 | 01:59 PM
Coskid's Avatar
Coskid
What are you trying to research it for? We need some more information as to what you are looking for before we can help.
Old Jul 26, 2010 | 02:02 PM
m-chan68's Avatar
m-chan68
It also helps if you post the entire VIN.
Old Jul 26, 2010 | 02:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by mtpcage
I was trying to research the rear end in my truck is the 3.73 standard. It sit a little high. I wouldn't think that would make a difference?
vin 1FTPW14566F
The VIN is no help, since it does not contain the AXLE code (regardless of what year the vehicle is). So...don't bother posting all 17 digits.
The AXLE code is listed separately on the Certification Label (1981 to date), on the Warranty Plate (1961/80), on the Rating Plate (1948/60).
There is an AXLE ID tag on the rear axle itself. Lists the type of axle, the ratio, whether Limited Slip is present...or not.
61 uni
Oct 7, 2012 08:20 PM
midmo
2009 - 2014 F150
Jul 17, 2012 09:57 PM
Itsme7
Jan 3, 2011 09:22 PM
kuttawa
Mar 12, 2004 07:55 AM
dgmess
1997 - 2003 F150
Oct 22, 2002 02:44 PM
