Sponsored by: Real Truck
Testing GEM
Old Jul 26, 2010 | 07:44 AM
Dutch930's Avatar
Dutch930
Testing GEM
Is it posible for a Ford dealer to test the GEM before replacing it? Or is it just a process of elimination?
Old Jul 26, 2010 | 11:29 AM
FireMe's Avatar
FireMe
The GEM itself isn't tested, but circuits going in and out are, as well as certain functions within the GEM using output state control.
But there is nothing we have that bench-tests the GEM itself.
Following the pinpoint tests in the manual usually give a good diagnosis.
Old Jul 26, 2010 | 12:03 PM
sdetweil's Avatar
sdetweil
is there an acronym decode list?
lately feel lost.. know others must be too
GEM, IPR, HPOP, etc,etc..
Sam
Old Jul 26, 2010 | 04:30 PM
Dutch930's Avatar
Dutch930
Sam
I have seen the GEM refered here as the General Equipment Module and also something else that I can't remember. Sorry, but can't help on the others.
Old Jul 26, 2010 | 06:02 PM
embry1123's Avatar
embry1123
IPR = Injection pressure regulator
HPOP = High Pressure Oil Pump
ICP = Injection control pressure
FICM = Fuel Injection Control Module
PCM = Power Control Module
TCM = Transmission Control Module
These are probably the most common, but there are hundreds more.
Old Jul 27, 2010 | 10:52 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
GEM is "Generic Electronic Module".
The 2001 service manual shows the module communication network as including:
The module communication network components — Super Duty Series F-250, F-350, F-450, F-550
l overhead trip computer (OTC) (optional)
l electronic crash sensor (ECS) module
l parking aid module (optional)
l generic electronic module (GEM)
l 4-wheel anti-lock brake (4WABS) control module (optional)
l rear anti-lock brake control module
l powertrain control module (PCM)
l auxiliary powertrain control module (APCM) (optional)
So, I think there's a way to communicate with it, but it takes the big fancy-schmancy Ford diagnostic setup to "talk" to it.
Furthermore, it appears pin 7 on the DLC connector goes to the GEM.
"² PINPOINT TEST D: THE GENERIC ELECTRONIC MODULE (GEM) DOES NOT RESPOND TO THE DIAGNOSTIC TOOL (Index)"
² D1: CHECK THE GEM C240A FOR DAMAGE
² D2: CHECK CIRCUIT 70 (LB/WH) BETWEEN THE DLC C227 AND THE GEM C240A FOR AN OPEN
² D3: CHECK FOR CORRECT GEM OPERATION
D2 CHECK CIRCUIT 70 (LB/WH) BETWEEN THE DLC C227 AND THE GEM C240A FOR AN OPEN
Measure the resistance between the GEM C240a pin 25, circuit 70 (LB/WH), harness side and the DLC C227 pin 7, circuit 70 (LB/WH), harness side.
l Is the resistance less than 5 ohms?
è Yes
Go to «D3».
è No
REPAIR the circuit between the DLC C227 and the GEM C240a. CARRY OUT the DATA LINK DIAGNOSTICS test.
xenfinityx
2004 - 2008 F150
May 24, 2015 06:50 AM
Hitagain
WTB - Parts & other
Apr 10, 2015 04:55 PM
Walleye Hunter
Aug 12, 2014 07:01 AM
sleepyhead416
Mar 7, 2010 06:17 PM
jakegypsum
Mar 27, 2004 10:07 AM
