My 06 F350 6.0 wont start. Never had a problem before. Went to work, came out and started it and let the AC run on my brake about 20 min. got off work 4 hrs later and it will just crank over...got a ride home and went back. There are no codes. Any Ideas?
There are many things that can cause a no-start, but one of the most common for the 05's through the 07's is a high pressure oil leak at the HPOP discharge "snap to connect" fitting (there are several other places that can leak also).
