starting problem
Old Jul 25, 2010 | 10:21 PM
rockhardhoosier's Avatar
rockhardhoosier
starting problem
I have a 2000 f250 with 7.3,my power chip fell out of my box today then truck died ,i plug it back in now my truck wont start ,check all fuses none blown,wait to start light not coming on,but it will start on starting fluid,any ideals
Old Jul 25, 2010 | 10:48 PM
rbaker6336's Avatar
rbaker6336
Double check fuse #30 under dash for WTS light
Old Jul 25, 2010 | 11:56 PM
MrBeechwood's Avatar
MrBeechwood
can you hear the fuel pump when you turn the key to the on position?
Old Jul 26, 2010 | 12:07 AM
megawatt00's Avatar
megawatt00
Were the keys in the ignition when you plugged the chip back in? If so you may have fried your PCM.
Old Jul 26, 2010 | 12:12 AM
robs01f250's Avatar
robs01f250
x2 on the keys in the ignition
Old Jul 26, 2010 | 06:55 AM
Peter@DP-Tuner's Avatar
Peter@DP-Tuner
PREMIUM SPONSOR
Most all of the time if a truck is running and the chip comes out it will kill the pcm and the chip. If it kills the chip and not the pcm and you plug it back in it will then kill the pcm also. Are you saying the truck will not start with the chip in or out? I know this is not what you want to hear but there is a very high probability 99.9999% the chip is fried and it killed the pcm also.
You can return it to the company you bought it from and they can verify. Also, check the pcm fuse and see if it is blown.
__________________
Peter
Forum Technical Support
www.dp-tuner.com
Use PM's to reach me!
Old Jul 26, 2010 | 09:40 AM
rbaker6336's Avatar
rbaker6336
From his thread in the superduty forum https://www.ford-trucks.com/forums/9...g-problem.html
the chip was hanging out of the box ,the truck was running and when i reached up to push it in it fell out ,truck died immediatly, and when i plug the chip back in it was getting hot,and is there anyway to check the chip
Old Jul 26, 2010 | 10:06 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Yes there's a way. When you put it on a chip burner and you apply power to it, it will buzz if it is fried. Don't keep it on the burner too long or it will take out the burner, too.
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Jul 26, 2010 | 02:05 PM
rockhardhoosier
yes the keys was in te ignition
Old Jul 26, 2010 | 02:07 PM
rockhardhoosier
i have double checked all fuses
Old Jul 26, 2010 | 02:10 PM
rockhardhoosier
starting problems
will i have to have pcm flashed if i install a new one
Old Jul 26, 2010 | 06:37 PM
rockhardhoosier
can the dealership test my pcm/ecm and tell me whether or not it is good
Old Jul 26, 2010 | 07:09 PM
tdpower's Avatar
tdpower
If the pcm code is the same you don't have to reflash. You could get a pcm from dp tuner with a mild tune installed on it cheaper than the cost of a pcm from the dealer probably. I don't know if the dealer could tell but most likely. They can hook it up to a scanner and do some tests.
Edit: You would probably have to take the truck in and not just the pcm for them to do any testing. Just wanted to clear that up.
Old Jul 27, 2010 | 08:01 AM
Peter@DP-Tuner
PREMIUM SPONSOR
This company has worked great for many customers of ours that needed pcms.
www.autocomputerexchange.com
You will need to provide them with your VIN, pcm code and DPC family number and you should get one just like what you had ready to go in.
__________________
Peter
www.dp-tuner.com
Old Jul 27, 2010 | 03:24 PM
rbaker6336's Avatar
rbaker6336
That's where I got the ECM for my Jeep, been a couple years now
